Audibility of a compression wave
  • Thread starter Thread starter jerromyjon
    Compression Wave
A compression wave can create an oscillation as it passes the ear, raising questions about its audibility and the factors influencing frequency. The speed of sound is primarily affected by temperature and atmospheric pressure, while the frequency of the oscillation is determined by the rate of compression and rarefaction, which varies with the sound source. The relationship between velocity, frequency, and wavelength is described by the equation V=fλ, indicating that sound propagation depends on temperature for ideal gases like air. The intensity of the sound, measured in decibels, is influenced by the magnitude of the pressure increase, while the frequency is mainly determined by the ambient conditions. Understanding these dynamics is essential for accurately modeling sound waves in various environments.
jerromyjon
Hello and thanks in advance for reading or contributing...
In regards to another thread here, https://www.physicsforums.com/threads/sound-as-condensation-or-rarefaction-of-air.817705/ , I am convinced a compression wave would cause an oscillation as it passes your ear. This raises the question as to whether this oscillation could be audible and what factors would determine the frequency.
To begin I believe that the wave should propagate through the air at the speed of sound, but I am uncertain if that is relevant. What determines the rate at which compression followed by rarefaction occurs? My intuition tells me the temperature and pressure (ambient as well as compressed) are the important factors, but I'm coming up short on techniques to model it.
λ
The source of the sound? For example rate of compression and rarefaction is faster for a 10kHz sine wave tone than it is for a 1kHz tone.
The equation V=fλ relates velocity, frequency and wavelength. The speed of sound varies with atmospheric conditions.
What you are describing is just a sound wave, and the frequency would just be determined by the frequency of the peaks and troughs that pass your ear. As for the propagation speed, it turns out to only depend on temperature for an ideal gas (which air is very close to).
If you drive a damped harmonic oscillator with a single pulse, it will vibrate. Not nearly as much as if you drove it with a nicely tuned sine wave. But it will vibrate.
That depends on the damping - if it's overdamped, it will do a single pulse, with no oscillations or ringing.
Likes jbriggs444
That is what I'm trying to determine. I am trying to make sure my feet are firmly planted on the ground before I contemplate a simplified scenario. I prefer to set the variables to realistic rounded figures for simplicity, such as 300K temperature (80F) and 100,000 Pa (roughly 1 atmosphere ambient pressure) but I'm not even sure what units are easiest to use.
As I didn't want to "derail" the other thread, I referred to it as a general description of what I aim to calculate. The premise is that a localized source of pressure increase in an air-tight room could create an audible oscillation as the pressure wave passes your ear. Now I am getting the impression that the magnitude of the pressure increase will contribute to the intensity (decibels) and simply the temperature will determine the frequency.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 44 ·
  • · Replies 19 ·
