This discussion revolves around troubleshooting an audio amplifier, specifically the Vivax AM 100, which exhibits buzzing noises and potential capacitor issues. Participants explore the function of various components, including capacitors and relays, and discuss possible causes for the observed problems.
- Exploratory
- Technical explanation
- Debate/contested
- Experimental/applied
- One participant describes a buzzing noise from the amplifier that seems to originate from a relay, along with wax residue on the board and a dented capacitor.
- Another participant suggests that the brown residue on a capacitor may indicate a problem, speculating that the capacitors could be power supply smoothing or audio coupling capacitors.
- A participant notes that the relay's chattering could be related to the circuit controlling it and questions the connection between the relay, capacitors, and nearby transistors.
- One participant explains a potential relay activation circuit that prevents high inrush current, suggesting that the relay may chatter due to insufficient voltage or leaky capacitors.
- Another participant mentions that relays in high-powered amplifiers may serve to disconnect speakers until the power supply stabilizes, indicating a possible common mode failure if both channels are affected.
- A participant expresses concern about safely testing the circuit live and considers measuring the signal waveform with an oscilloscope.
- One participant advises tracing the circuit before testing to ensure safety and understanding of the components involved.
- Another participant questions the condition of a burned plug behind the rectifier, while a later reply clarifies that it is not burned but covered in industrial glue.
- A participant shares their experience of tracing the circuit and observing a sine wave on the relay, noting that the chattering stopped unexpectedly but the amplifier still requires further research for repair.
- One participant reflects on their own amplifier's relay behavior, suggesting that the relay is designed to stabilize the amplifier before connecting the speakers, and discusses the complexity of the circuit logic driving the relay.
Participants express various hypotheses regarding the function and issues of the amplifier's components, with no consensus reached on the exact cause of the problems or the best approach to repair.
Participants mention potential issues with capacitor leakage and relay activation circuits, but details on the specific circuit design and its implications remain unclear. The discussion includes assumptions about the function of components without definitive conclusions.
