Automorphisms of Finite Fields
In summary, The conversation is about the effect of a field automorphism on a field with a non-prime subfield. It is mentioned that in a finite extension of finite fields, an automorphism must send the subfield to itself. This raises the question of what happens to the elements outside of the subfield, and it is clarified that they will also remain in the same set.
isaiah
I am trying to figure out the effect of a field automorphism on a field with a non prime subfield.
Say for example [tex]F_{2^{29}}[/tex], [tex]F_{2^{58}}[/tex] and [tex]F_{2^{116}}[/tex]
Let [tex]\alpha \in F_{2^{58}}[/tex]\[tex]F_{2^{29}} [/tex]
Under [tex]{\sigma}^{i}, 1 \le i \le 58[/tex] do we get any case where [tex]\alpha[/tex] becomes an element of [tex]F_{2^{29}}[/tex] ?
If not why not since the orbit of [tex]\alpha[/tex] under this automorphism will be 58.
Does it mean that the other elements shift to [tex]F_{2^{116}}[/tex]?
Thanks in advance.
Isaiah.
Remember that a finite extension E/F is normal iff every automorphism of E sends F to itself. Since any finite extension of finite fields is Galois, any automorphism of F_2^58 must send F_2^29 to itself. Does that answer your question?
Now what really happens to the elements of F_2^58\F_2^29 (ie exclude the ones in F_2^29)? Do they go to F_2^29 or do they remain in F_2^58\F_2^29?
Thanks,
Isaiah.
Well, an automorphism is one to one and onto, so if f:A->A is one to one and onto, and f(B)=B, we must have f(A\B)=A\B, mustn't we?
1. What is an automorphism of a finite field?
An automorphism of a finite field is a function that maps every element of the field to another element in the same field, while preserving the field's structure and operations. In other words, it is a bijective homomorphism from the field to itself.
2. How do automorphisms affect the elements of a finite field?
Automorphisms can change the order of elements in a finite field, as well as their position in the field's multiplication table. However, they do not change the addition or multiplication operations themselves.
3. What is the significance of automorphisms in finite fields?
Automorphisms play a crucial role in the study of finite fields, as they help to identify and classify different types of finite fields. They also have applications in cryptography and coding theory.
4. Can all elements of a finite field be mapped to each other by an automorphism?
No, not all elements can be mapped to each other by an automorphism. In fact, the number of automorphisms in a finite field is limited by the size of the field, and some elements may not have any automorphisms at all.
5. How are automorphisms of finite fields related to Galois theory?
Automorphisms of finite fields are closely related to Galois theory, as they are used to study the structure and properties of finite fields. In particular, Galois theory helps to determine the number and structure of automorphisms in a given finite field.
  • Linear and Abstract Algebra
