Average number of air molecules.
  • Context: Chemistry
  • Thread starter Thread starter eddzzz_2011
    Air Average Molecules
The discussion revolves around calculating the average number of air molecules per cubic centimeter at an altitude of 50 km, given the atmospheric temperature and pressure. Participants explore various equations and methods related to gas laws and unit conversions, with a focus on the implications of their calculations.
  • Homework-related
  • One participant presents the equation for pressure at height, Ph = P0e^-Mgh/RT, and attempts to calculate pressure at 50 km, arriving at 75.944 Pa.
  • Another participant questions the calculation of pressure and the use of the equation, suggesting that the pressure value may be incorrect.
  • There is a discussion about the relevance of the number of moles in the context of calculating the number of molecules, with some arguing that knowing the number of moles is essential for the final calculation.
  • Participants express confusion over the correct form of the equations and the units involved, particularly regarding the molar mass and its conversion to SI units.
  • One participant proposes an alternative equation involving logarithms, but later questions its validity and whether a conversion factor was missed.
  • There is a back-and-forth regarding the correct interpretation of the exponential function in the equations, with some participants clarifying the notation.
  • After several calculations, one participant arrives at a value for the number of air molecules per cubic centimeter but faces skepticism about the correctness of their units and final answer.
  • Another participant emphasizes the importance of checking units throughout the calculations to ensure accuracy.
Participants do not reach a consensus on the correct approach or final answer. There are multiple competing views regarding the equations to use, the correctness of calculations, and the significance of unit conversions.
Limitations include potential misinterpretations of equations, confusion over unit conversions, and unresolved steps in the calculations that may affect the final results.
eddzzz_2011
Hey guys. Hope you can help me out on this one. so here's the question:
At an altitude of 50km the average atmospheric temperature is 0^oC. What is the average number of air molecules per cubic centimeter at this altitude.
M = 28.97 g mol^-1
g = 9.81 ms^-2
R = 8.314 J K^-1 mol^-1
Ph = pressure at any given height
P0 = pressure at sea level
Ph = P0e^-Mgh/RT
Ph = P0e^-Mgh/RT
p @ 50km = 75.944Pa
75.944 x 1 x 10^-6
Ph = -------------------
8.314 x 273
= 3.346 * 10^-8. And then I need to divide this by 6.022 * 10^23
= 5.556 * 10^-32. Is this correct?
Cheers :)
eddzzz_2011 said:
75.944 x 1 x 10^-6
8.314 x 273
What are you calculating here? Ph? That is - pressure?
Ph = pressure at any given height.
M = 28.97 g mol^-1
g = 9.81 ms^-2
for
... 75.944 x 1 x 10^-6
...8.314 x 273
So what is 75.944?
I did write down pressure at 50km = 75.944 Pa. But this is incorrect. I may have used the equation n = PV but n = number of moles and would be useless, wouldn't it?
RT
Ok. I've just found another equation in my handout I have been given. It states that "if air pressure at sea level is taken to be 1atm then the equation simplifies to:
log(Ph) = -[Mgh*10^5/2.303RT]
so using this equation
log(Ph) = - [(29.97*9.81*50000*10^5)/(2.303*8.314*273)]
log(Ph) = -[1.47*10^12)/(5227.169)]
log(Ph) = -[281222971]
Ph = 10^-281222971
Ph = 0
This is obviously not correct :/ did I miss out a conversion factor?
And then you used this pressure again to calculate pressure Ph? That's what you wrote.
Note - using your equation and numbers I didn't get the same 75.944 for the pressure at 50 km.
Would it? Knowing number of moles in cm3 you can easily calculate number of molecules. You almost did it using Avogadro's number, you just got it the wrong way.
As fast as I can tell you missed one and added one that is not necessary. 28.98 is in grams, and I don't understand what is 105. Besides, now your pressure is in atm, previously it was in Pa. It is hardly a simplification, it is just a unit conversion (or a lousy wording in the handout).
Surely I must have got that the wrong way round of P0 and Ph. Which equation do I use? Do I use "log(Ph) = -[Mgh*10^5/2.303RT]" or "Ph = P0e^-Mgh/RT" I have attached a copy of the handout for you to have a little look at for that last equation. I noticed the teacher took log instead what I think should be ln.
Using n=pV I don't have a value for V. So that wouldn't work.
Thanks for all of your help Borek. Your a real help!
Doesn't matter which equation you use - in both cases the final result will be the same. Use whichever equation you want to calculate the pressure at 50km, that's your step number one. This is simple plug and chug, nothing more complicated than keying several numbers into your calculator.
No such equation as n=PV, more like n=PV/RT. Yes, you know the volume. You are asked about a number of molecules in 1 cm3.
right.
using n=PV/RT
V=1cm^3 = 1*10^-6m^3
R = 8.314 JK-1mol-1
T = 273K
P @ 50km = ?
Have to find Ph
Plug in values into
Ph = P0e^-Mgh/RT
Ph = 101325e^-(28.97*9.81*50000/8.314*273)
I keep getting a value of 0 for this.
I already told you were the problem is - please reread my earlier posts.
I know you said that 28.97 g mol-1 is not in its SI units? I don't know what to convert it to. Also the equation is Ph = P0e(-Mgh/RT) and not Ph = P0e^-Mgh/RT isn't it?
Everything else is in kg, so molar mass must be in kg/mol as well.
No idea what you mean - please elaborate on what e(-x) is.
Looks to me like you should brush up your math and units skills, otherwise you will be completely lost.
right I understand the kg part. And the equation i mean is it e to the power or e-. ie e^(-x) or e(-x).
Edit: I will be back on later tonight.
It still doesn't make sense. e to power -x is e-x. You are suggesting you see two different things, but I see only one.
What I wrote seems fairly understandable to me. But I emailed the teacher and it is e^(-x) so ignore that one.
Ok so the answer I have is 193.544.
Then
n=PV/RT
n= (193.544*1)/(8.314*273)
n= 0.086 air molecules per cubic centimeter of air @ 50km?
No.
Watch your units - you put volume as 1, but 1 of what?
Then, what you are trying to calculate is number of moles, this is not yet number of molecules.
Ah I want volume in m^3 yet it is in cm^3. so that's a factor of 10^-6.
so 1cm^3 = 1*10^-6 m^3
n= (193.544*1*10^-6)/(8.314*273)
n= 8.53 * 10^-8
So to work out number of molecules I have to times the number of moles by 6.022x10^23
number of molecules = 8.53 * 10^-8 * 6.022x10^23 = 5.135*10^8 number air molecules per cubic centimeter of air @ 50km
This is the right approach, but I am not convinced if your units are correct - and if they aren't, your answer is still orders of magnitude off. You ignore units all the time, so they are hard to follow and I am not going to browse the thread back to try to decipher them.
As a general rule: the final step of solving a question should be always check if the units of the answer are correct.
Ok. Thanks for all of your help
