Avoiding vehicular rear-end collision
  • Thread starter Thread starter PhizKid
    Collision
The discussion centers on calculating the necessary deceleration for car A, traveling at 161 km/hr, to avoid a rear-end collision with car B, which is moving at 29 km/hr and is 676 meters ahead. The participants derive equations of motion using kinematic principles, ultimately determining that the minimum deceleration required is approximately -1.42 m/s². Various approaches are discussed, including setting up equations for the positions of both cars over time and converting units for accurate calculations.
  • Understanding of kinematic equations for constant acceleration
  • Ability to convert units between kilometers per hour and meters per second
  • Familiarity with basic algebra and solving equations with two variables
  • Knowledge of the concept of relative motion in physics
  • Study the derivation and application of the kinematic equations in one-dimensional motion
  • Learn how to convert between different units of speed and acceleration
  • Explore the concept of relative velocity and its applications in collision avoidance
  • Practice solving problems involving multiple moving objects and their interactions
Physics students, automotive engineers, and anyone interested in understanding vehicle dynamics and collision avoidance strategies.
  • #31
Yes it an average deceleration or constant acceleration as in equation s=s0+v0t+0.5t^2.
  • #32
PhizKid said:
Sorry, I try to write neatly on loose leaf so I can take pictures of it to show my work, but it always comes out to chicken scratch. And it takes me forever to format the LaTeX.
So here is my work:
X_B - 676 = 8.0556t + \frac{1}{2}(0)t^2 \\ X_B = 8.0556t + 676
X_A = 8.0556t + 676 = \frac{1}{2}(44.72 + 8.0556)t
Can you explain the above equation? You've got the the distance traveled for car A as the average of the two car velocities multiplied by time. How does that come about?
  • #33
Sketching a graph is really helpful
As you see from the graph, the aim is to reduce the speed to less than the front car to avoid collision. It can be done just behind the front car or anywhere behind the front car
http://imageshack.us/a/img688/5505/60741537.jpg
  • #34
I used the 1D Kinematic formula x - x_0 = 1/2(v_0 + v)t. The intial velocity of the car A is 44.72 m/s, and the final velocity of car A 8.0556 m/s if it is to avoid collision with car B going at the same constant velocity of 8.0556 m/s.
  • #35
Okay, that's fine. What value did you find for t?
Edit: Never mind, I see where you calculated it above.
The value is fine. I think you just have a mathematical error in your calculations for a using that value of t back in post 28. Redo the calculation.
  • #36
So yea, I thought I covered all my grounds yet arrived at a solution that's pretty off...how is my calculation different from the ones mentioned earlier in this thread that got pretty much the exact answer they were supposed to get?
  • #37
See my most recent edit of my last post :smile:
  • #38
8.0556 + 676 = 44.72(36.875) - \frac{1}{2}a(36.875)^2
36.875^2 = 1359.765625
1359.765625 / 2 = 679.8828125
44.72(36.875) = 1649.05
8.0556 + 676 = 684.0556
So 684.0556 = 1649.05 - 679.8828125a
684.0556 - 1649.05 = -964.9944
So -964.9944 = -679.8828125a
-964.9944 / -679.8828125 = 1.41935401551
Damnit, so I got positive 1.41935401551 m/s as acceleration, which would mean it's entirely incorrect then.
Where did I perform the wrong calculation?
  • #39
On the left hand side of the first equation, you're missing multiplying the speed of car B by time. 8.0556*t + 676 = ...
  • #40
Oh wait I was using the wrong equation. I'm supposed to be using x - x_0 = (v_0)t + (1/2)at^2, not x - x_0 = vt - (1/2)at^2, since 44.72 m/s is the initial velocity of car A. So it does come out to -1.41935401551 m/s^2.
So the displacement of car A should equal the displacement of car B, which means I did forget to multiply the velocity of car B by the time...thanks
Edit: No, I had to use the subtraction formula with the final velocity and change the final velocity to 8.0556 m/s in the equation. This yields the correct -0.994 m/s^2 solution
Thanks
  • · Replies 17 ·
