Undergrad How Can a Set Fail the Scalar Identity Axiom in Vector Spaces?
The Scalar Identity Axiom in vector spaces states that for any vector \( u \), multiplying by the scalar 1 should yield the vector itself, represented as \( 1u = u \). However, a set can fail this axiom if scalar multiplication is defined in a non-standard way. For example, if scalar multiplication is defined as \( k \cdot = \), then there exists no scalar \( k \) such that \( k \cdot = \), thus violating the Scalar Identity Axiom.
  • Understanding of vector spaces and their axioms
  • Familiarity with scalar multiplication in linear algebra
  • Knowledge of fields, particularly the real numbers \( \mathbb{R} \) and complex numbers \( \mathbb{C} \)
  • Basic concepts of vector addition and operations
  • Explore non-standard definitions of scalar multiplication in vector spaces
  • Study the implications of violating vector space axioms
  • Learn about different fields used in vector spaces, including \( \mathbb{R} \) and \( \mathbb{C} \)
  • Investigate examples of vector spaces with unusual operations
Students of linear algebra, mathematicians, and educators seeking to deepen their understanding of vector space axioms and scalar multiplication.
elements
So I understand how to prove most of the axioms of a vector space except for axiom 10, I just do not understand how any set could fail the Scalar Identity axiom; Could anybody clarify how exactly a set could fail this as from what I know that anything times one results in itself
1u = u
1(x,y,z)=(x,y,z)
1(1,2,3) = (1,2,3)
1 (1,0,...,1) = (1,0,...,1)
I don't see how you could ever end up in a situation where you could end up with
1VV
1u = u
1(x,y,z)=(x,y,z)
1(1,2,3) = (1,2,3)
1VV
It can happen if you have a vector space with an unusual kind of scalar multiplication. Keep in mind that a vector space consists of a set of vectors over some field (often, the field of real numbers ##\mathbb{R}## or the field of complex numbers ##\mathbb{C}##), together with operations for vector addition and for multiplication by a scalar.
If scalar multiplication is defined like this
##k \cdot <x, y> = <kx, 0>##
then there is no scalar k for which ##k \cdot <x, y> = <x, y>##.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 16 ·
  • · Replies 25 ·
