Balance Beam: Solve + Explain Help
  • Thread starter Thread starter Sunshine12
    Balance Beam
3 replies · 2K views
Sunshine12
01"{
5. (12)A balance beam device comprised of a 200 cm long beam of unobtainium (no mass) ]
\]and a fulcrum located in the middle of the beam is balanced straight and level. At the right side of the beam system a mass of 30 kg is attached and at the other end of the beam system a mass of 25 kg is attached.
Find:
a) the torques acting on the system
b) the net torque and direction of rotation
c) Yippie the wonder dog, well beyond the prime of life, sees the problem of the unbalanced system with failing eyes. Yippie leaps up to the top of the fulcrum and after a less than stellar landing at the fulcrum point begins limping about on the left side of the fulcrum. The years have not been kind; our beloved Yippie has porked out to 25 kg (table orts you know). Help out, where must Yippie sit to bring the system into balance?
I missed this lecture and am absolutely not understanding this. Can someone please solve this + explain at each step?
You'd do best to read up on torques, you'll be spending a while on this stuff and having a good understanding from the get go will put you miles ahead.
http://en.wikipedia.org/wiki/Torque
Try this video lecture (and any from this series if you're having troubles), they really are golden.
http://video.google.com/videoplay?docid=6480119270481031622
i understand torque, i just don't understand how to balance these out and what not..i really need to see it solved to really get it x_x
In that case why don't you give (a) a stab, you just need to calculate the torque from each weight (distance x force).
