Balancing chemical equations polystomics and H2O + CO2/NO2
  • Thread starter Thread starter AMan24
    Chemical
The discussion centers on balancing chemical equations involving ammonium sulfide ((NH4)2S) reacting with nitric acid (HNO3) and lithium bicarbonate (LiHCO3) reacting with hypochlorous acid (HOCl). The proposed products for the first reaction include hydrogen sulfide (H2S) and ammonium nitrate (NH4NO3), while the second reaction is suggested to yield lithium hypochlorite (LiOCl), water (H2O), and carbon dioxide (CO2). The complexity of these reactions is highlighted, particularly due to the oxidation potential of nitric acid and the weak acidity of HOCl, which complicates the balancing process.
  • Understanding of chemical reaction balancing
  • Familiarity with oxidation-reduction reactions
  • Knowledge of weak acids and their behavior in reactions
  • Basic concepts of chemical equilibrium
  • Study the principles of balancing chemical equations
  • Learn about oxidation reactions involving nitric acid
  • Research the properties and reactions of weak acids, specifically hypochlorous acid
  • Explore chemical equilibrium calculations and their applications
Chemistry students, educators, and anyone involved in chemical analysis or reaction balancing will benefit from this discussion.
AMan24
(NH4)2S + HNO3 = ? - main problem
LiHCO3 + HClO = ? - check just in case problem
None.
I think it has to equal H2S + NH4NO3
Or H2S + NO2 + H2O
I've used multiple online chemical balancing calculators and they all give me different answers.
There's also the 2nd problem which I'm 99% sure on but just to be sure. I think it equals
LiClO + H2O + CO2
Sounds reasonable as a first approximation (although it depends a bit on the level - sulfides can be oxidized by the nitric acid, making things more complicated). Note - correct identification of the products doesn't mean the reaction equation is balanced.
Reaction of the carbonate with acid is very similar. No, there is no LiClO produced (actually hypochlorite is typically written as LiOCl).
I meant to write LiHCO3 + HOCl = LiOCl + H2O + CO2
Instead of LiHCO3 + HCl = LiOCl + H2O + CO2
And thanks for the help
This one is actually much more complicated, as HOCl is a weak acid. No idea what kind of answer is expected (on some level the one you gave can be OK, even if technically it is not correct). But - unless you have already learned about equilibrium calculations - you shouldn't worry.
10K
12K
13K
