Balancing Chemical Equations Using Oxidation Numbers
5 replies · 5K views
carlodelmundo
http://carlodm.com/pictures/problem.png
I'm stuck. Usually I balance the equation by multiplying the Fe(OH)2 and Fe2O3 by 3. However, I can no longer do this because Fe2O3 has two iron's per one molecule.
Do I multiply one by 6 and the other by 3?
Assume 2Fe(OH)2 is your reagent (why? because Fe2O3 contains two Fe atoms, just keep iron atoms forming one molecule of product togehter) - then you will have to multiply everything by 3. Basically that's the same as multiplitcation by 3 & 6, but it is easier to follow the reasoning.
I see. So I should balance the reactant iron first, to 2... then do the multiplications of irons by 3.
I've arrived at that step but the products side still looks like a mess. Is this where I stop all "techniques" and rely on intution and trial and error to figure out the balanced equation?
Once you have Fe and Cr balanced rest you have to "balance by inspection" - which, as you have correctly pointed out, is a fancy name for "intuition and trial and error" :wink:
Do you have to use ON method?
No we're not required to use the ON method... but it is a tool that we are able to utilize for ugly equations such as this. Thanks for your help! This'll come handy for reviewing my Chem exam.
