Ball thrown down simplify for time. HELP
A student throws a ball downward at 8.0 m/s from a height of 25 m and needs to determine the time until it hits the ground and its impact velocity. The initial calculation using the formula d = ViT + 1/2aT^2 yielded an incorrect time of 3.4 seconds instead of the correct 1.6 seconds. Participants suggest re-evaluating the equation to x = Vi*t + 1/2*g*t^2 and using the quadratic formula to solve for time. The discussion emphasizes the importance of correctly applying the quadratic formula to find the accurate time of descent. Understanding these equations is crucial for solving similar physics problems effectively.
reltz
A student throws a ball downward at a velocity of 8.0m/s from a height of 25m. How long until it hits the ground? What is the velocity of the ball as it hits the ground.
What is thee formula when simplifying for T(time)?
When using the formula d=ViT + 1/2a*d I get 3.4s, but the answer is 1.6s.
Welcome to PF.
Maybe think more in terms of
x = Vi*t + 1/2*g*t2
now I am still getig high answers... how do i simplify for t?
Didn't you get a quadratic equation? Use the quadratic formula. I don't think one of the solutions is too large.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
