Balloon and stone velocity: which solution is correct?
  • Thread starter rudransh verma
    Balloon
43 replies · 5K views · last reply
rudransh verma
New poster has been reminded to always show their work when starting schoolwork-type threads
A balloon starting from the surface of the earth has been ascending at a uniform velocity for 4.5 sec and a stone let fall from it reaches the ground in 7 sec. Find the velocity and height of balloon when the stone was let fall.
##s=ut+\frac12at^2##, ##v=u+at##
What value of t and a should be chosen?
jbriggs444 said:
You'll need to show some effort first.
##4.5u=u4.5+\frac12a4.5^2## $$u=u+\frac12a4.5$$
I am confused why a will be equal to -g. Doesn’t the acceleration of the balloon should be considered?
The balloon is not accelerating as per the problem statement. Once the stone is dropped, it is not influenced by the balloon any more.
This is just formulas with number. In order for us to be able to help you, you need to tell us why you have chosen those formulas and the values you have used.
It is not because the net force is zero. But why is there a g(acceleration due to gravity ) also? I don’t understand this? The balloon is not slowing down!
I guess that’s the most appropriate ones. We are given t, a. So the formula for s.
Yes, it is:
Homework Statement:: ... ascending at a uniform velocity for 4.5 sec
This was not my question. My question was why you applied them, to what part of the motion, and why you picked the values you picked. Also, what are the remaining unknowns representing?
Physics is not just plugging numbers into an equation. You need to understand the applicability and the reasoning involved.
##s=u4.5## That is the displacement of the balloon. Now same time t is used on the other side also (I am not sure). ##u4.5+\frac12a4.5^2##. I have already said I don’t know why a=-g when the balloon is not changing it’s velocity.
The book says this eqn but I don’t understand where is the acceleration part in question.
During which phase? You need to be specific.
What does the other side represent? Why is it equal and what is it describing?
Again, what is the equation describing?
When ascending .
I think when you find the eqn using ##v=u+at## you will see this is the 2nd eqn of motion we will achieve. I asked some time before and someone told me it’s the velocity *time(the other side of eqn). It’s describing displacement
the whole eqn is actually displacement =velocity *time.
When ascending .
So you have expressed a relationship between the displacement during ascent and the balloon velocity. Very good. Those are your sought quantities. However, with two unknowns you need two independent relationships to solve for both.
This brings us to:
What does the right hand side represent and why is it equal to the left hand side?
I said it It’s velocity*time which is displacement.
No, you are still talking about the left hand side. When is
s = ut + at^2/2
applicable in this problem?
What makes you think it is -g? You agree it is not accelerating, so it is zero. What do you notice when you plug that into your equation?
Gravity is always operating but it is the net force that determines the acceleration. In this case, the lift of the balloon exactly balances the force of gravity so the balloon rises at a constant velocity. Then the stone drops and that is a completely new problem for both the stone and the balloon. But you only care about the stone and you know the initial conditions.
It seems to me that what is puzzling you is the official solution in a book. What is leading everyone else on this thread to be puzzled is that you have not provided the relevant extract from the book, so we have no way to understand what you are misinterpreting.
Ahem, velocity has dimensions of length / time. Since no units of length are given explicitly or implicitly through a given value for the acceleration of gravity, the given number of 4.5 sec is not sufficient to lead to a numerical answer for the height of the balloon when the stone is let fall.
However, the velocity of the balloon (we are told) is uniform, therefore when the stone is let fall, the balloon will still be ascending with a velocity of 4.5 sec. Did I give away too much?
Edit: I misread the problem so all this is nonsense. See #21.
kuruman said:
Ahem, velocity has dimensions of length / time. Since no units of length are given explicitly or implicitly through a given value for the acceleration of gravity, the given number of 4.5 sec is not sufficient to lead to a numerical answer.
But if we assume a standard value for g (whatever the student has normally been told to use) there is enough info, right?
Yes, this is a problem with two equations and two unknowns.
Right, that's what I meant by "implicitly given" for the acceleration of gravity. My main point is that the student ought to exercise good judgment when writing numbers down and ensure that the units are consistent with the dimensions. It's a good habit to acquire, especially when one mixes numbers and symbols in an algebraic equation in which case including the units with the numbers is essential in order to sort out what's what.
As with a large majority of homework problems, this one can be first solved algebraically with the numerical substitution coming at the very end. This particular OP, despite past recommendations and exhortations, has resisted using algebraic manipulation and does not leave numerical substitution for last. If that's what OP insists on, that's fine as long as OP understands that the units must be handled correctly.
I misread this at first but it says the balloon is ascending at a uniform velocity for 4.5 sec. I first thought it said the velocity was 4.5 m/s but it is some unknown velocity for 4.5 sec.
You are not alone. I misread the "for" in front of 4.5 sec as an "of" . However, my other comments in post #19 about not substituting numbers until the very end stand.
Right !
I think of it as one equation with one unknown.
Two different segments of the journey, each with a different, but known acceleration and each taking a known amount of time. The overall displacement seems to be clearly indicated (as being zero).
”Find the velocity and height of balloon when the stone was let fall.” to me is explicitly two unknowns, but that is just splitting hairs. The relevant thing is to have the OP understand what is going on.
Thank you Everyone for so many comments.
I too think the net force is zero. So no acceleration. So no suvat eqn. But in my book they have used a=-g. So I am confused.
The solution is like this: ##4.5u=7u-\frac12g7^2##.
Frankly I don’t know which formula to use. But I have learned that if out of 5 variables(s,t,v,u,a)3 are given then use that eqn to find 4th.
That is for the falling stone, not for the rising balloon.
We know it was released at height (4.5s)u, at an upward speed of u, and will fall back to the ground under gravity in 7s.
I would however argue that the given solution
is still wrong.
I am sorry. Its ##-4.5u=7u-\frac12g7^2##.
##u=20.88 m/s##.
##h=94m##.
##u=20.88 m/s##.
##h=94m##.
So, do you understand why this is the case?
Absolutely not. Someone said to post the official answer. So I did. Please do explain!
So, the ##4.5u## you have correctly identified as the height of the balloon when it releases the stone. If you consider the fall of the stone, can you express how far from the release point it has fallen after an arbitrary time ##t##?
