Volume of Balloon Unchanged When Pressure Doubled & Temp Changes
  • Thread starter Thread starter ZiHao
    Balloon Pressure
The discussion centers on the relationship between pressure, volume, and temperature of a gas in a balloon, specifically under the constraints of the ideal gas law. When the pressure on the balloon is doubled, the temperature must also increase to maintain a constant volume. According to the ideal gas law (PV=nRT), if volume (V) remains constant and pressure (P) doubles, the temperature (T) must also double to satisfy the equation. Participants emphasize the direct correlation between temperature and pressure changes in a gas-filled balloon.
  • Understanding of the Ideal Gas Law (PV=nRT)
  • Basic knowledge of gas behavior under varying pressure and temperature
  • Familiarity with the concept of kinetic molecular theory
  • Ability to manipulate algebraic equations
  • Study the Ideal Gas Law and its applications in real-world scenarios
  • Explore the concept of isothermal and adiabatic processes in gases
  • Learn about the effects of temperature on gas pressure and volume
  • Investigate the kinetic molecular theory and its implications for gas behavior
Students studying physics or chemistry, educators teaching gas laws, and anyone interested in understanding the behavior of gases under varying conditions.
ZiHao
A balloon is filled with a gas to a certain volume at a certain pressure at 22.0 degrees Celsius. If the pressure exerted on the balloon is doubled. explain what must the temperature ( in degrees celsius) be so that the volume of the balloon doesn't change.
If the temperature changes, the volume of the balloon will also change. Higher temperature,more energetic therefore more particle collisions, vice versa. So how can the temperature change but the volume of the balloon does not change( according to the questions)? Thanks!
What makes you think that the balloons volume does not change? The volume of the balloon will change as the pressure does.
I moved the thread to our homework section.
The pressure inside and the pressure outside both increase.
What do the words in the problem statement "so that the volume of the balloon doesn't change." mean to you?
Please write down the equation for the ideal gas law. From this equation, if V is constant, what does the temperature have to do if the pressure doubles?
I thought that OP was under the assumption that the volume cannot change. Apologies.
  • · Replies 16 ·
11K
12K
