Design the Most Stable Base for a Rectangle
The discussion focuses on designing a stable base for a rectangular structure measuring 3 feet high, 2 feet wide, and 6 inches deep. The front of the rectangle is 1 pound heavier than the back, necessitating a design that can withstand impacts from two specific scenarios: an object weighing 5.5 ounces at 95 mph and another weighing 6.8 ounces at 72 mph. Participants seek insights into materials and structural designs that can ensure stability under these conditions.
  • Understanding of basic physics principles related to force and impact.
  • Knowledge of material properties and weight distribution.
  • Familiarity with engineering design concepts for stability.
  • Experience with structural analysis techniques.
  • Research materials with high impact resistance for structural bases.
  • Learn about weight distribution techniques in engineering design.
  • Explore structural analysis methods for dynamic loads.
  • Investigate the principles of stability in tall structures.
Engineers, product designers, and hobbyists involved in structural design and stability analysis, particularly those working with dynamic load scenarios.
JasonFrank
Hey guys,
Im in the middle of a project and need help with the base for it. I have to develop a base for a rectangle 3 feet high by 2 feet wide by 6 inches deep. The front of the rectangle is 1 pound heavier than the back and will stand 2 feet off the ground.
The base must be able to make the rectangle stay in place while having a object weighing 5.5 ounces coming at a straight on downward angle at a velocity of up to 95 mph. Also I need another base to withstand a 6.8 ounce object coming from a straight on upward angle at 72 mph.
Could someone help me out with the most stable design for both scenarios?
Thanks for the post! Sorry you aren't generating responses at the moment. Do you have any further information, come to any new conclusions or is it possible to reword the post?
Echo that. Why is the front heavier if it's a true rectangle? Different material? Or is the "front" actually a second rectangle built into the top of the first? I'm picturing something like a medieval siege tower, but that can't be right.
10K
12K
24K
  • · Replies 42 ·
