Baseball Parametric Equations with Wind
2 replies · 6K views · last reply
Futmex128
A baseball is hit with an initial velocity of 103 ft/sec, with an initial height of 3 ft, and at an angle of 41 degrees. There is a wind blowing 22ft/sec in the direction opposite to the horizontal path of the ball at an angle of depression of 12 degrees. Assume that gravity is the only force affecting the path of the ball. Disregard air resistance and spin.
V=Velocity
For the X equation it should be Vcos(D)T where D=the degree at which the baseball is hit
and T=time
For the y equation it should be Vsin(D)T - 16t^2 + initial height
I know that if the wind was blowing exactly horizontally then the equation for X would be X=103cos(41)T - 22. But, I'm not sure how the wind's angle of depression would affect this. It also has to alter the equation for Y since the wind blows downwards so the height will go down. Can someone explain how to account for the wind's angle of depression? Thank you.
?? The problem says "Assume that gravity is the only force affecting the path of the ball. Disregard air resistance and spin. "
The wind should be completely ignored!
This problem comes down to whether it's a trick question or a misleading question. If the wind speed is given but you're meant to be ignoring all other forces except gravity, then it's a trick question. Else, if you need to take wind into consideration it's a misleading question.
Simply put, stupidity on their part.
