Solving xy''-y'=0 Using y=xr: Are r=0 and r=2 the only possible solutions?
  • Thread starter Thread starter Marco Lugo
The discussion centers on solving the differential equation xy'' - y' = 0 using the trial solution y = x^r. It is established that the only valid solutions occur for r = 0 and r = 2, as demonstrated through specific examples and derivative calculations. The reasoning is that for r = 0, y is constant, leading to zero derivatives, while for r = 2, the derivatives yield a valid equation. Attempts to use other values of r, such as 1 or those outside the range of 0 to 2, do not satisfy the equation. The general solution to the differential equation is noted as y = A x^2 + B, confirming the identified solutions.
Marco Lugo
Let xy''-y'=0. Try a solution of the form y=xr. Is this a solution for some r? If so, find all such r.
xy''-y'=0
y=xr
The answer I came up with was: r*x-r*x=0, for all r.
But in the solutions it says, "y = xr is a solution for r = 0 and r = 2."
Is there some reason it would only work for r=0 and r=2?
The answer you came up is not the correct one. Check the second derivative of y(x)=x^r.
xy''-y'=0
y=xr
What you should do is plug in some concrete examples. I'll give you two and see if you can work out the rest: <br /> y = x^1 \\<br /> y&#039; = 1 \\<br /> y&#039;&#039; = 0 \\<br /> <br /> \implies xy&#039;&#039; - y&#039; = x(0) - 1 \neq 0
So you can see it doesn't work for r = 1. Now let's see why it does work for r = 2<br /> y = x^2 \\<br /> y&#039; = 2x \\<br /> y&#039;&#039; = 2 \\<br /> <br /> \implies xy&#039;&#039; - y&#039; = x(2) - 2x = 0
as required. Now try plugging in a few values of r less than zero and a few greater than 3 and see if you can see why they don't work.
Thanks I see that now haha
Thanks for your help; it makes sense now that I see it. Would there be away to find r directly or would I just have to try them all?
You kind of have to think a bit outside the box to figure out which values of r are "different".
If r = 0 then y is a constant so all if its derivatives are 0
If r = 2 then its first derivative is a function of x but its second derivative is a constant
if r < 0 or r >2 then all the derivatives are functions of x
Try out the few odd ones then go from there. For instance, you don't need to try out r = 4 after you try out r = 3 because they follow the same pattern. Same with r = -1 and r = -2
Ah yes I see. Alright thanks for your help!
Hey there's actually a way you can do it without too much thinking: <br /> y = x^r \\<br /> y&#039; = rx^{r-1} \\<br /> y&#039;&#039; = r(r-1)x^{r-2} \\<br /> <br /> \implies xy&#039;&#039; - y&#039; = x[r(r-1)x^{r-2}] - rx^{r-1} = x^{r-1}r(r-1 -1) = x^{r-1}r(r-2)
Which equals zero for all x when r = 0 or r = 2. Sorry I didn't notice this before. A bit stressed out with my own midterms coming up. Cheers.
It is not too difficult to get the general solution to this d.e. which is
y = A x2 + B
Which includes the solutions given.
Wow thanks! I'll definitely keep this in mind when working on similar problems. No worries, good luck on your midterms!
y = A x2 + B
How did you get to that solution?
First tell me if you've checked it works. Which if it does may even point you to how you could have solved it.
  • · Replies 21 ·
