Basic relativity question (probably easy for everyone on here xD)
  • Thread starter Thread starter jayjay713
    Relativity
The discussion revolves around calculating the speed of a proton emitted from a quasar moving away from Earth at 0.850c, which reaches Earth at a speed of 0.519c. The user attempts to apply the relativistic velocity addition formula, u = (u' + v) / (1 + (u'v/c²)), but struggles to determine the proton's speed relative to the quasar. The correct interpretation of the variables in the equation is crucial for solving the problem accurately.
  • Understanding of special relativity concepts, specifically relativistic velocity addition.
  • Familiarity with the symbols used in the relativistic velocity addition formula.
  • Basic knowledge of the speed of light (c) and its significance in relativity.
  • Ability to interpret and manipulate algebraic equations involving velocities.
  • Study the relativistic velocity addition formula in detail, focusing on its application in various scenarios.
  • Learn how to define and interpret variables in physics equations, particularly in the context of special relativity.
  • Practice solving problems involving relative motion, especially with objects moving at significant fractions of the speed of light.
  • Explore examples of similar problems involving quasars and other astronomical objects to reinforce understanding.
Students studying physics, particularly those focusing on special relativity, as well as educators and anyone interested in understanding the dynamics of high-speed particles in astrophysical contexts.
jayjay713
a quasar is moving away from Earth with a speed 0f 0.850c. It emits a proton that eventually reaches Earth with a speed of 0.519c relative to the earth. How fast is the proton moving relative to the QUASAR.
u = u' + v / 1 + u'(v) / c^2
u = 0.578c relative to earth.
How do I go about getting an answer relative to the object emitting the proton?
thanks for help. appreciate it
Your equation is kindof hard to read, since it has several division signs. And are u,u' and v the absolute values of the speeds?
Also, Is this homework? You should show your own working first, since we're only meant to help with homework.
A quasar is moving AWAY from the Earth with a speed of 0.850C. Itemits a proton that eventually reaches the earth, and is traveling at a speed of 0.519C relative to the EARTH. how fast is the proton moving RELATIVE to the QUASAR?
my attempt: u = u' +v / (1 + u'v/c^2)
u = 0.578c RELATIVE to EARTH.
however, I am looking for the speed RELATIVE to the QUASAR. I do not know how to do that with that given formula!
any ideaS? thanks
any ideaS? thanks
The equation is still hard to read, man. Does it mean:
u= \frac{u'+v}{1+ \frac{u' v}{c^2}}
And you said that u=0.578c relative to earth, but that doesn't make sense, because you already know the speed of the proton and the quasar relative to earth.
I think you should start by defining what u, u' and v mean in your equation.
i don't know what it means? it's on the formula sheet there is an example using it. all i want to know is the speed of the proton relative to the quasar...
QUASAR<-0.85c-<QUASAR "shoots" PROTON>0.519>PROTON <EARTH>
the velocities are relative to earth.
THERE! I DREW IT OUT :) Does that make sense?
Yes, I already understood that bit. But I'm trying to help you through the question. Since you have the equation, you just need to work out what the symbols mean. Try to work it out from your formula sheet.
Do you see the contradiction between the two things in red? That's why BruceW said it didn't make sense.
In any case, how did you manage to come up with 0.578c? I don't get that when I plug in the numbers the way I assume you did.
