Basic trig question: reference angles
Reference angles are not explicitly proven in basic trigonometry but are understood through the periodic properties of trigonometric functions. Their utility arises from the definitions of sine and cosine in relation to the unit circle, where angles are defined by the arc length. The periodic nature of these functions allows for the computation of values for angles beyond the first quadrant using reference angles. While the discussion touches on the relationship between periodicity and reference angles, it emphasizes that the periodicity is inherent to the trigonometric functions themselves, independent of reference angles. Ultimately, understanding these concepts is rooted in the definitions and properties of angles and the unit circle.
cupu
Hello,
Preparing for a test, I've had to go through some very basic trigonometry and I've got to thinking why reference angles "work". I've gone through my study material and through another trigonometry book I have around the house and references angles are never proven, the theorem is just stated and then used.
Intuitively it makes sense right away; for example how sine goes from 0 to 1 as the angle goes from 0 to π/2, then as the angle increases, the reference angle in quadrant 2 has the same value as the angle in standard position. But after that I'm thinking that it only works because it's defined that way ...
Anyway, it's probably *really* easy, that's why it's not explained anywhere (that I've searched) but, starting from the basic definition of sin/cos/etc. in a right angled triangle I can't see how the theorem of reference angle is proven; any pointer is much appreciated.
Thank you very much!
Mathematics news on Phys.org
That is correct. Everything in mathematics boils down to the definition.
Start by stating the definition.
But the definition is that way because of the definition of what an angle is in the first place.
The definition is useful because of the periodic properties of the trig functions and the rules for addition and subtraction.
It will probably make more sense if you imagine you didnt have a calculator and you have been hired to construct a table of values for the sine of an angle for any angle ... how would you go about making your job easier?
Have you look further afield:
http://www.sparknotes.com/math/trigonometry/trigonometricfunctions/section4.rhtml
... I think the main problem with answring your question is that you have not explained what the problem with that sort of explanation is.
Likes 1 person
Hello,
Thanks for the reply. My problem is just that when I think about reference angles, they make sense because of the periodic nature of trig functions; then I think that the periodicity is there because we use reference angles to compute the values of trig functions for angles between (pi/2, 2pi) and then my brain deadlocks.
Also somewhere online - I think wikipedia, but can't find the link anymore - this was called the "Theorem of reference angles"; I expected a theorem to have a proof, but couldn't find it or deduce it.
I can easily live with the "that's the way it's defined", I just thought/think that I'm missing something very evident.
Cheers!
That's not correct.
The periodicity comes from what the trig functions are.
Reference angles are useful because of the periodicity.
eg.
The size of an angle is defined as the length of arc of the unit circle subtended by the angle.
The radien is when the unit circle is defined as that having a radius of 1.
The other way to define a unit circle is to make the circumference 1 - which most people then divide into 360 degrees.
Watch how the trig functions are defined in terms of the unit circle:
http://www.mathsisfun.com/algebra/trig-interactive-unit-circle.html
... see where the periodicity comes from? No reference angles used.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
