Gravitational Potential Energy and Oscillations of a Bead Attracted by Spheres
  • Thread starter Thread starter geoffrey159
    Bead Spheres
The discussion focuses on the gravitational potential energy and oscillations of a bead influenced by two gravitational spheres. The potential energy of the bead is derived as U(x) = -\frac{2GmM}{\sqrt{x^2+a^2}}. The bead's speed as it passes the origin is determined using conservation of mechanical energy principles. Additionally, the frequency of small oscillations around the origin is calculated as ω = √(2GM/a³), confirming the stability of the equilibrium point at the origin.
  • Understanding of gravitational forces and potential energy
  • Familiarity with conservation of energy principles
  • Knowledge of calculus, particularly derivatives and integrals
  • Basic concepts of harmonic motion and oscillations
  • Explore gravitational potential energy calculations in multi-body systems
  • Study the principles of conservation of mechanical energy in oscillatory motion
  • Learn about the stability of equilibrium points in dynamical systems
  • Investigate the mathematical modeling of oscillations using differential equations
Students in physics, particularly those studying mechanics and oscillatory motion, as well as educators and researchers interested in gravitational interactions and energy conservation principles.
geoffrey159
A bead of mass m slides without friction on a smooth rod along
the x axis. The rod is equidistant between two spheres of mass M.
The spheres are located at x = 0, y = ± a, and attract the
bead gravitationally.
(a) Find the potential energy of the bead.
(b) The bead is released at x = 3a with velocity v0 toward the
origin. Find the speed as it passes the origin.
(c) Find the frequency of small oscillations of the bead about the origin
(a)
The two working forces acting on the bead are the attraction of both spheres:
##\left\{
\begin{array}{}
\vec F_{s_+} = \frac{GmM}{(x^2+a^2)^{3/2}} (-x \hat x + a \hat y) \\
\vec F_{s_-} = \frac{GmM}{(x^2+a^2)^{3/2}} (-x \hat x - a \hat y)
\end{array}\right.
Their sum, ##\vec F= -2GmM \frac{x}{(x^2+a^2)^{3/2}} \hat x ##,
is clearly a central force, so it is conservative and has a potential function :
##U(x) - U(x_0) = - W_{x,x_0} = 2GmM \ \int_{x_0}^x \frac{r}{(r^2+a^2)^{3/2}} dr = - \frac{2GmM}{\sqrt{x^2+a^2}} + Cst ##.
So, without the constants, the potential energy is ## U(x) = -\frac{2GmM}{\sqrt{x^2+a^2}} ##
(b)
I use conservation of mechanical energy, if (a) is ok, (b) is straightforward
(c)
The origin is a stable equilibrium point because it is a minimum of the potential function: ##\frac{dU}{dx}(0) = 0## and ##\frac{d^2U}{dx^2}(0) = \frac{2GmM}{a^3} > 0 ##.
Now around 0 : ## U(x) \approx U(0) + \frac{1}{2} \frac{d^2U}{dx^2}(0) x^2 ## which is the potential energy of a spring with constant ## k = \frac{d^2U}{dx^2}(0)##
Then the frequency of oscillations around equilibrium is ##\omega = \sqrt{\frac{k}{m}} = \sqrt{ \frac{2GM}{a^3}} ##
Is that correct ?
All looks right.
You could get (a) more easily by just summing the two potentials.
Alternatively, having found the force in (a), the quickest route to (c) is to write down the expression for acceleration and approximate it to ## -\frac{2GMx}{a^3}##
I see, thank you very much !
  • · Replies 18 ·
  • · Replies 19 ·
