Bead on a hoop+accelerating elevator
  • Thread starter Thread starter PhMichael
    Bead Elevator
8 replies · 3K views
PhMichael
http://img839.imageshack.us/img839/8904/bead.jpg
Uploaded with ImageShack.us
The picture speaks for itself. I'm asked to find the minimum velocty that this bead should be given so that it will reach point B. 2. The attempt at a solution
I've solved this question using energy conservation with a "new gravity": [tex]g_{eff}=g+a[/tex] , so that:
[tex]0.5mV^{2}=m(g+a)(2R) \to V=2 \sqrt{(g+a)R}[/tex]
and this is the right answer.
However, supposing I want to solve this question using Newton's 2nd law in an accelerating frame, so:
[tex]m \vec {a}_{rel} = \vec{F}_{real} - m \vec{a}_{frame}[/tex]
If i take the positive values to be in the direction of the relative acceleration, i'll obtain:
[tex]m \frac{V^{2}}{R} = mg + ma \to V= \sqrt {(g+a) R }[/tex] ?
Why is that? Am I missing something?
What does this equation mean? Is it the correct condition for the bead to reach B? :wink:
Obviously it's not correct because the answer is messed up :D , but assuming i didn't know the correct answer i'll say yes, it the the correct one. I don't see where's the problem.
What does this equation means? hmmm ... Isn't it simply the modified 2nd law of Newton in accelerating frames?
That equation describes the motion of the bead in the lift frame at the lowest point, given that the bead doesn't experience normal force from the hoop. But that doesn't guarantee the bead can climb up to B :wink:
EDIT: I see something deadly wrong here. At the lowest point, in the lift frame, gravitational force and fictitious force point down, but the centripetal force points up. Normal force cannot be zero.
Reagarding the normal force, I really forgot all about it (in addition, I'm given that the hoop is frictionless) ... so the equation should be:
[tex] m \frac{V^{2}}{R} = mg -N + ma [/tex]
and at point B we want it to be: [tex]N \neq 0[/tex] ... but I still have 2 unknows :/
You got the wrong signs! It should be:
[tex] m \frac{V^{2}}{R} = -mg +N - ma [/tex]
Anyway, this doesn't show any possibility that the bead can go up to B. You may disregard this force method; otherwise, if you continue with it, the equation you get is eventually the same as the energy equation.
P.S.: Some more comments on this. You may repeat the idea that [tex]N \neq 0[/tex] is the condition taken from some other problems, but it does not apply to this problem. We always have [tex]N \neq 0[/tex], as the bead is forced to follow a circular motion.
yeah, I used the energy equation at first and got it right but I just wanted to see whether I get the same answer form the force method. So are you saying it's insolvable this way?
It's solvable, but it's actually the same as energy method. Here it is:
1 - Because the bead is forced to follow a circular path, the normal force must always satisfy that. In other words, the normal force is determined by the circular motion.
2 - The only thing that matter is that if the component of other forces (i.e. weight & fictitious force) along the hoop can pull the bead down before the bead reaches B. Let [tex]\phi[/tex] denote the angle coordinate of the bead to the horizontal. We have:
[tex]-m(g+a)cos(\phi) = mRd\omega/dt=mR\omega d\omega/d\phi[/tex]
Therefore: [tex]\int_{V/R}^{0}R\omega d\omega = -\int_{-\pi/2}^{\pi/2}(g+a)cos(\phi)d\phi[/tex]
And that is the same as the energy equation.
Hello could you look at ? the post /showthread.php?t=612910
