Beam hinged to wall with a cable (torque, etc)
1 reply · 12K views
lizzyb
Hi. I've tried to answer this questions four times and so far none of my answers have been correct. Any help is greatly appreciated!
A uniform 48 kg (m) beam at an angle of 24 degrees (theta) with respect to the horizontal has length of 38 m (L). It is supported by a pin and horizontal cable. The acceleration of gravity is 9.8 m/s^2 (g). What is the magnitude of the total force exerted by the pin on the beam?
So far:
[tex]\sum F_x = F_h - T = 0[/tex] horizontal component of pin - tension of cable
[tex]\sum F_y = F_v - mg = 0[/tex] vertical component of pin - mass of beam * gravity
[tex]\sum \tau = \sin \theta L T - \cos \theta L m g = 0[/tex]
Does this look ok to you? For the torque, I'm trying to use the moment arm times the magnitude of the force.
Thank you.
The last equation should have been:
[tex]\sum \tau = \sin \theta L T - \cos \theta \frac{L}{2} m g = 0[/tex]
and that took care of it.
