Beat frequency from two slightly different sound waves
1 reply · 4K views · last reply
Inertigratus
So I had a homework assignment which I couldn't complete in time. One of the questions was what the title is about. I also asked for help earlier in the homework section.
See my post: https://www.physicsforums.com/showthread.php?t=487676.
Right now I just want to learn how this works for the coming test.
Perhaps the title in my other post is misleading as I don't really know if there is a "beat frequency" and/or if it has anything to do with the problem.
Any ideas on how to solve this?
Thanks!
Sure. Start with what you know about sound beats when you have two waves and then use superposition to add a third wave. The time dependence of the amplitude at a fixed location for two waves is
$$y(t)=\cos(2\pi f_1 t)+\cos(2\pi f_2 t)=2\cos \left(2\pi\frac{f_1+f_2}{2}t\right) \cos \left(2\pi\frac{f_1-f_2}{2}t \right)$$When the frequencies are close you can approximate ##f_1\approx f_2=f_0## and write
$$y(t)=2\cos (2\pi f_0) \cos \left(2\pi\frac{f_1-f_2}{2}t \right)$$When you have a third wave you take all the possible combinations and write $$y(t)=2\cos (2\pi f_0) \left[ \cos \left(2\pi\frac{f_1-f_2}{2}t \right) +\cos \left(2\pi\frac{f_2-f_3}{2}t \right) +\cos \left(2\pi\frac{f_3-f_1}{2}t \right) \right]$$ In this particular problem we have ##f_1=200~ \mathrm{Hz}##, ##f_2=201~ \mathrm{Hz}## and ##f_3=202~ \mathrm{Hz}## which gives $$y(t)=2\cos (2\pi f_0) \left[ 2\cos (2\pi~\Delta f~t ) +\cos (2\pi \times 2\Delta f~t ) \right]$$where ##\Delta f=0.5~\mathrm{Hz}##. You can use any number between 200 and 202 Hz for ##f_0##. Of course, the intensity is the square of the amplitude.
