Homework Helper
- 2,157
humbleteleskop said:Data stream 1
A: 0 1 0 0 1 0 1 1 0 1
B: 0 1 0 0 1 0 1 1 0 1
Data stream 2
B: 1 0 1 1 0 1 0 0 1 0
So if Type I experiment counts only matching values, it concludes the first sequence is 100% correlated and the second sequence 0% correlated, thus failing to recognize the second sequence is actually 100% correlated as well? It seems they should really be sampling and analyzing data over larger sequences, not just making one to one comparison.
At this point you are so lost...
You can measure any values you like in an experiment of your own making. I really can't help you on that. The rest of us have standard setups to discuss and I have given you any number of those. Everyone knows the difference between matches and correlation. And anti-correlation too, which is what you are mentioning. None of this has anything to do with a Bell test beyond what I have explained so far.
The issue is the average relationship between pairs of entangled particles. In quantum theory, that relationship remains in place as long as the pair is described by a single wave function. In classical theory, that relationship ends when they are no longer in causal contact because classical theories follow local realism.
I will again ask you to read the references I have provided. When you understand those, many of your questions will be resolved. Your idea that the scientists working this area do not understand the basics of their experiments (and are comparing wrong sequences) is... well, what do you really expect?
Learn the background, THEN try to tear it apart. Not the other way around.
