Free Beam Bending: Find Complete Answer & More
The discussion focuses on analyzing beam bending under concentrated forces, specifically addressing scenarios with both centered and off-center loads. The participants emphasize the importance of applying correct boundary conditions, such as zero shear and moment at the free end of a cantilevered beam. They suggest treating the problem in two parts: first analyzing a centered load and then modifying the approach for off-center forces. The conversation highlights the necessity of balancing forces and moments to determine the beam's deflection accurately.
  • Understanding of beam theory and mechanics of materials
  • Familiarity with statics principles, including force and moment equilibrium
  • Knowledge of boundary conditions in beam analysis
  • Experience with cantilever beam behavior and deflection calculations
  • Study the principles of beam deflection using Euler-Bernoulli beam theory
  • Learn about calculating reactions and deflections for cantilever beams under various loading conditions
  • Research methods for analyzing beams with off-center loads, including moment distribution
  • Explore software tools for structural analysis, such as SAP2000 or ANSYS
Structural engineers, civil engineering students, and professionals involved in mechanical design or analysis of beam structures will benefit from this discussion.
spovolny
Consider a beam with an upwards concentrated force applied to its center. This is equilibrated by a distributed downwards force. There are no displacement boundary conditions. I've tried approaching this with simple beam theory, but I can't get a complete answer (shear, moment, slope, deflection) unless I assume a deflection value somewhere. What is the best way to get the complete answer for this problem?
I'm also curious about what happens if the concentrated force is off-center (equilibrium then maintained by applying a moment along with the force). The lack of symmetry complicates things further.
i.e. the beam is balanced on a fulcrum ... how would you normally do this if, say, the beam were clamped at one end?
I appreciate the quick reply. Clamped at one end means a cantilevered beam, so moment/shear are zero at the free end and slope/deflection are zero at the clamped end. I see how my problem is like a beam on a fulcrum, but I don't want to necessarily say that the center deflection is zero.
I did impose zero shear/moment at the free ends. I also imposed zero slope at the center, but this breaks down if the concentrated force isn't centered.
Just stick to one problem at a time - treat the simpler case where the concentrated force is centered and then modify the approach to allow for uncentered force.
This is a statics problem - all forces and moments balance, the main trouble is that the beam bends and you want to know how much by right?
What's wrong with modelling as two half-length beams clamped at one end? You will need to account for the reactions due to the other side.
The main thing is to look at how you would treat that situation.
13K
20K
