How Do You Calculate the First Three Bernoulli Numbers?
  • Thread starter Thread starter sara_87
    Bernoulli Numbers
The discussion focuses on calculating the first three Bernoulli numbers, B1, B2, and B3, using the series expansion of x/(e^x - 1). Participants emphasize the importance of deriving the Taylor series directly rather than substituting into an existing series, which can lead to convergence issues. The correct limits for B0 and B1 are established using l'Hôpital's rule, resulting in B0 = 1 and B1 = -1/2. The conversation highlights the need for a clear understanding of Taylor series and the process of differentiation to find the Bernoulli numbers. Overall, the thread illustrates the complexities involved in the calculation and the necessity of proper mathematical techniques.
sara_87
Let
x/((e^x)-1)= 1 + B1x+B2((x^2)/2!) + B3((x^3)/3!)+…
where Bn are called the Bernoulli numbers. Determine B1 , B2 and B3.
I think this one: (1+x)^n = 1 + nx + ((n)(n-1)/2!)(x^2)+...
i wrote it in this form -x(1-e^x)^(-1) to perhaps make it easier to use the maclaurin series but i still don't get what the question asks us to get
Expand the LHS in power series. Read off the coefficients.
i understand what you are saying but i don't know what to do...when i expand the first tem isn't 1 it's -x
Well google for Bernoulli numbers to see what the correct definition is.
You are trying to use a formula for the expansion of 1/(1-s) and apply it to the case where s=1. Don't do it. As matt said, the B's are just the derivatives of x/(e^x-1) taking the limit as x->0.
?? Then you expanded wrong! The MacLaurin series for x/(ex- 1) has first term the limit as x goes to 0. That certainly is 1!
thanx all for your help and time; i googled bernoulli numbers and i got the answer, but i still don't understand i think i should ask a real person and they might be able to talk me through it
You can't just use the taylor series of 1/(1-s) and then substitute e^x for s. That series does not converge in the correct place when s=e^x (e^x >1 for x>0). So you just have to find the Taylor series of x/(e^x - 1) directly from the definition of a Taylor series. I.e. differentiate and let x tend to 0.
So what's B_0? It is the limit as x tends to zero of x/(e^x-1)
We can't take that limit directly, but by l'Hopital it is the same as the limit f 1/e^x as x tends to 0, and that is just 1.
What about B_1? The derivative is (e^x-1 - xe^x)/(e^x - 1)^2. We're going to have to apply l'hopital again.
Doing it once, we need the limit of (-xe^x)/(2e^2x-2e^x), but we see we need to do it again.
So we want to find the limit of (-e^x -xe^x)/(4e^2x - 2e^x) as x tends to zero, and that is -1/2. Which Wolfram tells me is what I should have been expecting.
'You can't just use the taylor series of 1/(1-s) and then substitute e^x for s. That series does not converge in the correct place when s=e^x (e^x >1 for x>0). So you just have to find the Taylor series of x/(e^x - 1) directly from the definition of a Taylor series. I.e. differentiate and let x tend to 0.'
yeah that i managed to pick up! thank you though; I'm at a maths center and i have half a dozen questions for the maths teacher so i'll just add this one in there so that i fully understand...i did actually understand everything you said and what the other tips were so you didn't waste your time :)
What else is there to understand? You know you can't just use an extant Taylor series, and thus have to find your own. I gave the derviation of B_0 and B_1 in the above edited post. What more do you need to know?
If you want to do it directly, then consider putting in the series expansion of e^x first.
e^x -1 = x+x^2/2! + x^3/3! +...
Now divide by x.
(e^x-1)/x = 1+x/2! +x^2/3! +... x^n/(n+1)! +...so x/(e^x-1) = 1/(1+x/2! +...)
now use the expansion of 1/(1-s) and assume it all works, and I think you get the same answer as before. The first two terms are certainly correct, 1 and -1/2.
i get most of it lol
just need somenone to talk me through it to make sure it sinks in
(i need someone to tell me 'yes sara! you're right! that was a difficult question!')
We ARE 'real people'! Aren't we?? :eek:
Personally, I don't think it was a difficult question, but I do think you tried to make it difficult. I.e. instead of actually working out the Taylor series by hand you wanted to make a short cut and substitute into a divergent series.
Please don't think that is belittling your efforts - many's the time I've made a simple thing far too complicated as well.
It was certainly a tedious question - I was fed up just working out B_0 and B_1, never mind getting on to do B_2 and B_3.
If someone asked you to find the Taylor series about 0 of x/(e^x-1) you'd be able to do it.
