Best way to learn the equations in physics
  • Thread starter Thread starter Briandaflyin
    Physics
The discussion emphasizes that learning physics equations should not be isolated from understanding the underlying concepts. Memorizing equations like F=ma or Schrodinger's equation is deemed less effective than grasping their meanings and applications. Participants highlight that physics is fundamentally about concepts, and equations serve as a language to express these ideas. They suggest that rather than seeking books that focus solely on equations, resources like Feynman's Lectures on Physics can provide a comprehensive understanding. The consensus is that mastering the manipulation and application of a few key equations, rather than rote memorization, is crucial for success in physics.
Briandaflyin
I am wondering the best way to learn the equations in physics. I have already learned most of the concepts through other means ie. Googling. Is there any books that only teach the equations.
Brian
Which equations? I found myself doing SO many problems in Phys 1 that it just started to come naturally. But on the tests we were given and equation sheet, though I rarely used it.
I am not taking phys 1, just self learning. I was juat wondering if there any good books to read that teach you them.
Brian
You can't really separate the math from the concepts so there's no such book as 'just equations'. Wouldnt make much sense.
For example what is Newton's second law, conceptually mean? If you said something like, "Force is equal to the rate of change of momentum" or something equivalent then all you did was put the equation into words. Mathematics is really the language of physics.
Feynman's Lectures on Physics are full of equations. Why not start with them?
I'll try Feynman's lectures, is it a book or audio
Eemmmmm... dude, memorizing the equations isn't going to get you anywhere in physics. Even something as simple as F=ma is significantly harder than it looks.
Yeah, I got a textbook at the library, so I guess it will work. Thanks everyone
This.
I've never once gone out of my way to memorize equations. Some of them, like Schrodinger's equation from quantum mechanics or the first law of thermodynamics, do eventually embed themselves into your head after a while, but memorizing them won't help you do physics better. What matters more are the concepts: what the equations mean and how to manipulate them mathematically is far more important than being able to recite them.
In fact, there are only a handful equations in physics. Conservation of energy, for example, shows up in several forms:
1. m g h + \frac{1}{2} m v_i^2 = \frac{1}{2} m v_2^2
2. dU = T \: dS - p \: dV
3. - \frac{\hbar^2}{2m} \nabla^2 \Psi + V \Psi = i \hbar \frac{\partial \Psi}{\partial t}
etc.,
They're all pretty much the same equation: energy before (+ work, if applicable) = energy after. It's just ONE equation, disguised as several. No need to memorize it in its myriad forms. Focus more on knowing when to applying the concept.
  • · Replies 71 ·
