Marcus95
- Messages
- 50
- Reaction score
- 2
A thin bi-convex lens with refractive index n has spherical surfaces with equal radii of curvature r and measured focal length f. The lens floats horizontally on the surface of liquid mercury so that its lower surface effectively becomes a spherical mirror. A point object on its optical axis is then found to coincide with its image when it is at a height u above the lens. Determine r and n.
Thin lens equation: ##\frac{1}{f} = \frac{1}{u} + \frac{1}{v}##
Refraction at Spherical Surface: ##\frac{n_1}{u}+\frac{n_2}{v} = \frac{n_2-n_1}{R}##
Lensmakers Equation: ## \frac{1}{f} = (\frac{n_2}{n_1}-1)(\frac{1}{R_1}+\frac{1}{R_2})##
I am very uncertain on how to handel the spherical mirror at the back of the lens and I would like to think through the problem before beginning with calculations.
Assuming that f is known, we may use the lens makers equation to express either r or n in the other two variables.
However, I don't know how to use the other information. Had it been a straigth mirror at the other end, I think we migth be able to say that the image is simply reflected and ##u = v##, but I am uncertain about this as well.
My other problem is, that if the ligth never exits the second face of the lens, maybe it cannot be viewed as a full lens? Isn't it then only a refraction at one sperical interface? Or does the spherical mirror compendate for this?
Very Thankful for explanations! :)
