So that I can refer to the various gearing setups more easily:
[SS] = small rear gear with (equal-sized) small front gear
[LL] = large rear gear with (equal-sized) large front gear
[ML] = medium rear gear with large front gear
[SM] = small rear gear with medium front gear
(etc.)
bill9999 said:
We all know that there are several options of front sprocket/rear sprocket combinations that achieve the same gear ratio. i.e. A large front sprocket with medium rear or medium front with larger rear will produce the exact cadence at a given speed.
The combinations [ML] and [LM] do not result in the same bicycle speed for the same pedalling frequency. Did you mean, "A large front sprocket with medium rear or medium front with
small rear will produce the exact cadence at a given speed"? This makes sense for the case when the gear ratios L:M and M:S are the same. Then, for a given pedalling frequency, your bike would travel at the same speed in either gearing combination. I think this was your question (?)
I couldn't possibly estimate the effects of the complex stresses, frictions etc. on the chain and gears in each of the two cases. For my opinion, I would say that riding "feels smoother" when using the largest pair of gears possible, i.e. [ML] seems to make for an easier ride than the equivalent [SM]. Similarly, when I'm riding I feel that [LL] gives me less friction than [MM] or [SS]. This is just the impression I get from my own, very subjective, experience.
