Bilinear transformation not working
  • Context: MHB
  • Thread starter Thread starter Sneaky6666
    Transformation
The discussion revolves around the application of bilinear transformation to warp a rectangle into a quadrilateral, as described in a referenced document. Participants explore the mathematical formulation, implementation in code, and issues encountered during the transformation process.
  • Technical explanation, Experimental/applied, Debate/contested
  • One participant presents a bilinear transformation problem involving specific coordinates for a square and a quad, detailing the matrices used to derive coefficients for the transformation.
  • Another participant questions the construction of the matrices and suggests verifying the cardinal points for accuracy, emphasizing the importance of sanity checks.
  • A third participant explains the mathematical relationships used to derive the coordinates from the matrices, indicating the separation of the equations into two systems for independent coefficients.
  • One participant shares experiences of successfully applying the transformation to warp an image but notes specific areas where the transformation failed, providing visual examples.
  • Another participant identifies numerical instability in the quadratic function used for calculating coordinates as a potential issue and suggests three methods to improve accuracy, including using a more stable quadratic formula, translating the square to the origin, and scaling it to a unit square.
  • There is a reiteration of the methods proposed to address the numerical instability, with one participant expressing gratitude for the shared solutions and acknowledging the learning opportunity presented by the discussion.
Participants express differing views on the effectiveness of the initial transformation approach, with some identifying issues and others proposing solutions. The discussion remains unresolved regarding the optimal method for achieving accurate transformations.
Participants mention potential numerical instability and the impact of coordinate transformations on accuracy, but the specific mathematical steps and assumptions involved in the calculations remain unresolved.
Sneaky6666
I want to try this bilinear transformation of a rectangle to a quad described here
http://www.fmwconcepts.com/imagemagick/bilinearwarp/FourCornerImageWarp2.pdf
on page 4.
I have the square
$$(500,900)(599,900)(599,999)(500,999)$$
and the quad
$$(454,945)(558,951)(598,999)(499,999)$$
It looks like this
Where the ith entry of the quad and square coordinates above are corresponding corners.
With that in place, I can make the following matrices
$$\begin{bmatrix} 1 & 500 & 900 & 450000 \\ 1 & 599 & 900 & 539100 \\ 1 & 599 & 999 & 598401 \\ 1 & 500 & 999 & 499500 \end{bmatrix} \begin{bmatrix} a_0 \\ a_1 \\ a_2 \\ a_3 \end{bmatrix} = \begin{bmatrix} 454 \\ 558 \\ 598 \\ 499 \end{bmatrix}$$
$$\begin{bmatrix} 1 & 500 & 900 & 450000 \\ 1 & 599 & 900 & 539100 \\ 1 & 599 & 999 & 598401 \\ 1 & 500 & 999 & 499500 \end{bmatrix} \begin{bmatrix} b_0 \\ b_1 \\ b_2 \\ b_3 \end{bmatrix} = \begin{bmatrix} 945 \\ 951 \\ 999 \\ 999 \end{bmatrix}$$
If I solve for them I get
$$a0=-709.911845730028$$
$$a1=1.50964187327824$$
$$a2=0.709621467197225$$
$$a3=-0.000510152025303541$$
$$b0=148.305785123967$$
$$b1=0.611570247933884$$
$$b2=0.85154576063667$$
$$b3=-0.000612182430364249$$
But then when I run this python script (I want to simulate manually, converting the point (454, 945) on the quad to the point (500,900) on the square), I get a different answer. I get (442.90822654, 1024.0)...
Code:
    X = 454
    Y = 945
    a1=1.50964187327824
    b0=148.305785123967
    b2=0.85154576063667
    A = b2*a3 - b3*a2
    C_one = (b0*a1 - b1*a0)
    C = C_one + (b1*X - a1*Y)
    B_one = (b0*a3 - b3*a0) + (b2*a1 - b1*a2)
    B = B_one + (b3*X - a3*Y)
    V = (-B + (B*B - 4*A*C)**0.5 ) / (2*A)
    U = (X - a0 - a2*V) / (a1 + a3*V)
    print U,V
Does anyone know what's wrong?
Thanks
Hmm, interesting. The bilinear transformation code seems correct to me. I noticed, though, that there appears to be a .jpg file concerning your original matrices where you compute the $a_0, a_1,$ etc, that didn't load. Could you please give some background on how you constructed those matrices?
Incidentally, wanting to check your four "cardinal" points is a very good idea! Sanity checks in general are essential.
[EDIT] For reference, when I copy your code to Mathematica (really Wolfram Programming Cloud), I get the same result you do. So I don't think you're getting any weird sort of round-off or numerical error here.
I added the missing image above. And the matrix is based off the pdf file on page 4.
X = a0 + a1U + a2V + a3UV
Y = b0 + b1U + b2V + b3UV
Where X, and Y is coordinates on the quad, and U,V and coordinates on the square. By substituting the 4 pairs of corresponding corner coordinates, I get 8 equations. But a and b coefficients are independent, so I can separate it into 2 systems of equations of 4 unknowns.
I did a test and tried to warp an image and this seems to work in general, but then in two places the formula messed up. See these two pics.
The left eye got messed and the right leg got messed too. The above example quad is for the right leg.
original:
warped:
using this warp template:
I was able to fix it, using three methods. The issue was numerical unstability in the quadratic function to calculate the y coordinate.
1. Use the much more stable quadratic formula
http://www.it.uom.gr/teaching/linearalgebra/NumericalRecipiesInC/c5-6.pdf
2. translate the square to location 0,0.
3. Scale the square into a unit square.
3. helped a bit, 2. not sure if it made a difference, and 1. was a huge boost in accuracy.
3. translate the square to location 0,0.
2. Scale the square into a unit square.
Excellent! I'm glad you found something that worked out, and thanks so much for posting it here for our edification. You learn something new every day. I had no idea that the regular quadratic can be numerically unstable. It makes sense given the explanation - subtraction is usually the culprit.
  • · Replies 59 ·
