Binned Maximum Likelihood fit in python?
9 replies · 4K views · last reply
ORF
TL;DR
Is there any built-in function to perform Binned Maximum Likelihood fit in python standard libraries?
Hi,
I have been using Python for a while now, but so far for Least-squares fits using curve_fit from Scipy.
I would like to start using Likelihood method to fit binned and unbinned data. I found some documentation in Scipy of how to implement unbinned likelihood fit, but I have not managed to make it work for a simple exponential...
[CODE lang="python" title="Unbinned likelihood fit"]
from scipy.stats import rv_continuous
import numpy as np
class myfunc_gen(rv_continuous):
"Exp distribution"
def _pdf(self, x,a):
return np.exp(x*a)
myfunc = myfunc_gen(name='exp')
a = 1.
x = myfunc.rvs(a, size=10)
a1, loc1, scale1 = myfunc.fit(x, a, floc=0, fscale=1)[/CODE]
I found that Pandas has some fit capabilities, but still quite limiting.
Question: is there any functionality in python equivalent to curve_fit from Scipy for Binned/Unbinned likelihood fits?
Thank you for your time.
Cheers,
ORF
This is exactly what scipy-stats-rv-continuous-fit is for. Saying 'it doesn't work' is not going to find a solution, you need to be more specific:
Was the result not what you expected? Was it close but not accurate enough? Did it fail to execute? Does it run too slowly? Did your computer catch fire?
Hi,
In this case the result is wrong.
For other simple fitting function it complains either convergence is very slow or directly it reaches 100 iterations and it stops without converging. Probably there is something wrong with my code.
Still, this method is for unbinned data. Is there any method for binned data?
Cheers,
ORF
ORF said:
In this case the result is wrong ... Probably there is something wrong with my code.
There is quite a lot wrong with your code. Take a look at how the expon distribution is defined in scipy's source. The key parts are:
Python:
    def _pdf(self, x):
        # expon.pdf(x) = exp(-x)
        return np.exp(-x)
Note that there is no scale parameter in there, _pdf must be defined with a scale factor of 1: you add the scale factor when creating an instance of the class or when calling its methods.
And note that the exponential PDF is not ## e^x ##.
Python:
expon = expon_gen(a=0.0, name='expon')
The exponential distribution is supported in ## [0, \infty) ## but the default support for a rv_continuous distribution is ## (-\infty, \infty) ##. This can be overriden with the (unhelpfully) named parameters a and b: https://docs.scipy.org/doc/scipy/reference/generated/scipy.stats.rv_continuous.html
rv_histogram.fit?
I think you probably need a course or a book on statistical methods with Python, unfortunately I can't recommend any.
Thanks, but that example is exactly as the one in the documentation (replacing beta distro by exp). I would like to do unbinned and binned likelihood fits using a custom pdf/fitting function.
Python:
    def _pdf(self, x):
        return np.exp(-x)
Python:
The exponential distribution is supported in ## [0, \infty) ## but the default support for a rv_continuous distribution is ## (-\infty, \infty) ##. This can be overriden with the (unhelpfully) named parameters a and b: https://docs.scipy.org/doc/scipy/reference/generated/scipy.stats.rv_continuous.htmlrv_histogram.fit?
Hi, thanks for your very complete explanation. After normalizing the pdf it converges nicely.
I hope I can continue from it.
Thanks,
ORF
Do let us know how you get on with rv_histogram.fit for your binned data - I have never used it, but it looks like it should work similarly to the continuous fit once configured properly.
