Binomial and geometric distributions
9 replies · 5K views
sara_87
i was doing some exercises nut I'm not sure if my answers are correct
1) X~B(5,0.25) i have to find:
a) E(x^2) and my answer was 2.5, is this correct?
b) P(x(>or=to)4) and my answer was 0.0889, is this correct?
2) X~Geom(1/3) i have to find:
a) E(x) my answer is 1/3
b) E(x^2)
c) var(x)
d) P(X=4) my answer is 0.988
e) P(X>2) my answer is... -(1/18)
i don't know how to compute b) and c)
and i think d) is wrong
and i know e) is wrong.
can someone help please.
Thank you very much
Would "yes" or "no" answers help you? Show what you did to get those answers and we can point out exactly where, if at all, you went wrong.
my working out is:
1) a) E(x^2)= var(x)+E(x)^2 = np(1-p+np)= 5(1/4)(1-1/4-5/4)=2.5
b) P(x(>or = to)4)= 1-P(x=3)-P(x=2)-P(x=1)-P(x=0)
using the formula P(x=m)=(nCm)P^m(1-p)^(n-m)
=1-(15/1024)-(135/512)-(405/1024)-(243/1024)=91/1024=0.0889
2) a)E(x)=1/p=1/(1/3)=3
b) and c) i have no idea
d) using the formula P(x=m)=P(1-P)^(m-1)
P(x=4)=1/3(1-1/3)^3=8/81=0.988
e) P(x>2)=1-P(x(<or=to)2)=1-P(x=2)-P(x=1)-P(x=0)
=1-(1/3)(2/3)-(1/3)(2/3)^0-(1/3)(2/3)^-1=-1/18
thank u very much
1a is correct except you meant +5/4) not -5/4).
For 1b can you write out the nCm terms?
2a is correct.
For 2b use the same formula as in 1a.
2c: Var(Geometric(p)) = (1-p)/p^2; see http://en.wikipedia.org/wiki/Geometric_distribution
2d: 1/3(1-1/3)^3 = 8/81 < 0.1 so it cannot be > 0.9 (i.e., you have made a fraction computation error).
2e: if the exponent is k-1 then k = 1, 2, ... OTOH, if the exponent is k, then k = 0, 1, 2, ... In either case, exponent term > 0 so it cannot be -1. See http://en.wikipedia.org/wiki/Geometric_distribution
for 1b:
my working including the ncm terms:
=1-[(5C3)(1/4)^3(1-1/4)^2]-[(5C2)(1/4)^2(1-1/4)^3]-[(5C1)(1/4)(1-1/4)^4]-[(5C0)(1/4)^0(1/1/4)^5]
=91/1024=0.0889
for 2e:
i looked at the link but i still haven't figured out what i had done wrong with my working out.
thank u very much for everything else.
sara_87 said:
for 2e:
You have the exponential term -1, which shouldn't be there under either definition of the geometric distribution (referenced on the page I linked to).
My guess is you should have 1 - (1/3)(2/3)^2 - (1/3)(2/3)^1 - (1/3)(2/3)^0, but you should verify that.
For 1b, you have:
1 - Binomial[5, 3] (1/4)^3 (1 - 1/4)^2 - Binomial[5, 2] (1/4)^2 (1 - 1/4)^3 - Binomial[5, 1] (1/4) (1 - 1/4)^4 - Binomial[5, 0] (1/4)^0 (1/1/4)^5, where Binomial[n,m] stands for nCm.
Binomial[5, 3] = Binomial[5, 2] = 10
Binomial[5, 1] = 5
Binomial[5, 0] = 1
so the expression is:
1 - 10 (1/4)^3 (1 - 1/4)^2 - 10 (1/4)^2 (1 - 1/4)^3 - 5 (1/4) (1 - 1/4)^4 - 1 (1/4)^0 (1 - 1/4)^5
=1 - 10 (1/4)^3 (3/4)^2 - 10 (1/4)^2 (3/4)^3 - 5 (1/4) (3/4)^4 - 1 (1/4)^0 (3/4)^5
= 1 - 10 (9/1024) - 10 (27/1024) - 5 (81/1024) - 1 (243/1024)
= 1- (90 + 270 + 405 + 243)/1024
= 1 - 1008/1024
= 1 - 504/512
= 8/512
= 1/64
= 0.015625
oh okay i see so the formula i used will only work if k=1,2,3... (as u said before)
so if i used the formula P(x=m)=P(1-P)^(m-1)
and did 1-P(x=2)-P(x=1)
=4/9
would that work?
no it should only be for x=2 and x=1 as these are the ones strictly less than three
Your OP stated "P(x(>or = to)4)," doesn't that exclude x=3?
