Efficiently Calculate Binomial Expansion Coefficients | Homework Equations
The discussion focuses on calculating the ratio of binomial expansion coefficients A6 and A14 for the polynomial (2x² + 3x + 4) raised to the power of 10. The key insight is that the coefficients Ar and Br are equal due to the symmetry in the expansion, allowing for a direct relationship between them. By substituting x with 2/x, the problem simplifies, enabling the calculation of the coefficients without tedious case analysis. The final conclusion emphasizes the importance of recognizing the relationship between the coefficients to efficiently solve for their ratio.
  • Understanding of binomial expansion and coefficients
  • Familiarity with polynomial algebra
  • Knowledge of substitution techniques in algebra
  • Ability to manipulate summation notation
  • Study the properties of binomial coefficients in polynomial expansions
  • Learn about the symmetry in binomial expansions and its applications
  • Explore advanced techniques in algebraic manipulation and substitution
  • Practice problems involving ratios of coefficients in polynomial expansions
Students studying algebra, mathematicians interested in polynomial expansions, and educators looking for effective methods to teach binomial coefficients.
erisedk
Consider the expansion (ax2 + bx + c)n = ∑(r=0 to r=2n) Ar xr------------------(1) , where Ar is real ∀ 0 ≤ r ≤ 2n
Replacing x by c/(ax) and using the property ∑(r=0 to r=2n) Tr = ∑(r=0 to r=2n) T2n-r ,
we get (ax2 + bx + c)n = ∑(r=0 to r=2n) Br xr ----------------------(2).
Hence we get a relation between Ar and Br by comparing like power of xr
0 ≤ r ≤ 2n from both equations.
Let (2x2 + 3x + 4)10 = ∑(r=0 to r=2n) Ar xr then the value of
A6 /A14 is
I tried doing what the paragraph says--
I substituted (2/x) for x (c/ax = 2/x).
I got (8/x^2 + 6/x + 4)10
But I don't want a relation between A and B
I want the ratio of the coefficients of the terms with x^6 and x^14.
I tried doing it using binomial expansion by making cases for when the powers of (4+3x) and (2x^2) add up to 6 and 14.
For 6, I got 4 such cases. For 14, I got 8. However, solving all the Cs and stuff is very time consuming and doesn't seem the right way to go.
The important thing to recognize is that your ##B_r## should be equal to your ##A_r## since they are expanding the same polynomial.
By introducing the substitution, you can find a way to relate ##B_{2n-r}## to ##A_r## which works for r=6.
Keep it in the sum notation to see the relationships.
##\sum_{r=0}^{2n} A_r x^r ##
##\sum_{r=0}^{2n} B_r \left(\frac{c}{ax}\right)^r=\sum_{r=0}^{2n} B_r \left(\frac{c}{ax}\right)^{2n-r}##
Do some algebra to equate the powers of r, and see what comes out.
