Biot Savart polygon with n edges
  • Thread starter Lindsayyyy
    Polygon
2 replies · 3K views · last reply
Lindsayyyy
I want to calculate the magnetic field with Biot Savart in the given drawing in the point P=(0,0,0)
Biot Savart
I have already problems in parametrizising the conducter loop. Can anyone give me some hints on how to do this?
Thanks for the help.
  • Regular octagon centred on the origin of x and y axes, with a radius l drawn from the centre to a vertex, and current I labelled on the left edge pointing downward.
Just break the polygon into each segments, and compute the magnetic field at the origin due to each segment and add them up. It is clear the contribution from each segment is the same. So in fact, all you need is compute from one segment, then multiply by 8.
Let's pick one, say the one on the left side labeled by the I. You can parametrize points on the segment by its polar angle [itex](-l, l \sin \vartheta)[/itex] to where [itex]\sin \frac{7\pi}{8} \le \vartheta \le \sin \frac{9\pi}{8}[/itex].
Write out at each [itex]\vartheta[/itex]: What it the distance to origin? What is the result of [itex]d\mathbf{l} \times \mathbf{\hat{r}}[/itex] as a function of [itex]\vartheta[/itex].
Then just plug these into Biot-Savart and integrate away.
Thanks for your help, but how do you get to 7pi/8 etc?
