Calculating Bivariate Probability with Joint and Marginal Distribution Functions
  • Thread starter Thread starter forty
    Probability
The joint probability density function for random variables X and Y is defined as f(x,y) = 2 for 0 ≤ y ≤ x ≤ 1, with marginal probability density functions calculated as f(x) = 2x and f(y) = 2 - 2y. The expected values are E(X) = 2/3 and E(Y) = 1/3. For the probability calculations, P(X < 1/2) is determined to be 1/4, while P(X < 2Y) can be approached by analyzing the region defined by the inequality and performing a double integral. P(X = Y) is confirmed to be 0 due to the continuous nature of the variables, as the line X = Y has zero area in the probability distribution.
forty
Let the joint probability density function of random variables X and Y be given by
f(x,y) = 2 if 0 <= y <= x <= 1
and 0 otherwise
a) calculate the marginal probability density functions.
f(x) = 2x
f(y) = 2-2y
b) find E(X) and E(Y).
E(X) = 2/3
E(Y) = 1/3
c) calculate P(X<1/2) , P(X<2Y) and P(X=Y).
P(X<1/2) = integral from 0 to 1/2 of 2x dx = 1/4
but as for the other 2 I have no idea on how to do them. do they also involve the marginal distribution functions? Any help as always is greatly appreciated.
Thanks.
and 0 otherwise
f(x) = 2x
f(y) = 2-2y
These are correct, except remember that the equations are valid only for 0 \leq x \leq 1 and 0 \leq y \leq 1. Both f(x) and f(y) are zero for x and y outside those intervals.
E(X) = 2/3
E(Y) = 1/3
Yep.
Correct.
Try calculating P(X<2Y) directly from the joint probability density function. All you need to do is work out what the region "X < 2Y" looks like and how to perform a double integral over that region.
For P(X=Y) my suggestion is similar: what does the region "X=Y" look like in the X-Y plane, and can you immediately identify the probability without even integrating?
Thanks for the help..
I can see by looking at the graph that the answer should be 1/2 but i don't know how to set up the integrals, i know it involves the f(x,y) and a double integral over dx and dy.
as for P(X=Y) is that 0 (does this have anything to do with it being continuous)?
Notice that the original joint density function is zero unless Y <= X. What does this say about the probability that X < 2Y?
Yes and yes. The line X = Y is a region with zero area (it's just a line), so in order for the probability to be nonzero, there would have to be a concentration of probability on that line, which requires at least one non-continuous random variable.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 18 ·
