BJT Analysis Question: Solving for Vb with Voltage Divider Method
4 replies · 2K views · last reply
eehelp150
Hand-drawn BJT bias circuit schematic: +10 supply to a 70K resistor and 1K collector resistor, the 70K resistor joined to a 30K resistor to ground at the base, NPN transistor with beta = 100, and a 100 ohm emitter resistor to ground.
KVL
This is the solution given:
VB = (VCC*30k)/(70k+30k) = 3V
Why is a voltage divider being used to find Vb?
Your question should be in the problem statement, not the attempt.
Are you sure that VB is the same as Vb? Looks to me like a determination of a Thevenin equivalent for the base voltage supply. Was there also a Thevenin resistance calculated (paralleling the 30 k and 70 k resistors)?
VB is Vb.
Thevenin resistance was calculated for 30k and 70k.
What is your task? To find the DC voltage VB at the base?
Don`t forget that you have a loaded resistive voltage divider - loaded with the transistor base current.
This is what I imagine the author of the solution was going for:
Circuit schematic of an NPN transistor common-emitter stage: a +10 V supply feeds a 1 kΩ collector resistor, the emitter has a 100 Ω resistor to ground, and the base connects through resistor R_B to a voltage source V_B with its + terminal marked.
With ##V_B## and ##R_B## being determined as the Thevenin equivalent of the base voltage divider.
