Blade root attachment design
  • Thread starter Thread starter Nutria360
The discussion revolves around the design of blade root attachments for an axial fan, focusing on the geometric relationships and considerations for dovetail and fir tree designs. Participants explore the implications of different designs on machining capabilities, rotordynamics, and aeroelasticity, while seeking foundational information for their projects.
  • One participant seeks information on the geometric relationships of blade root attachments, specifically dovetail and fir tree designs.
  • Another participant notes that the design will depend on the type of fluid used, such as air, steam, or combustion gas.
  • Some participants highlight that machining capabilities are crucial in determining the design choice, with fir tree designs being favored for their load distribution and material efficiency, despite requiring higher precision machining.
  • A participant expresses a desire to design an axial fan and mentions the need to consider rotordynamics and aeroelasticity in their design process.
  • There is a suggestion that a dovetail design may be simpler for initial geometry and calculations, which one participant agrees to consider for their design.
  • Another participant emphasizes the importance of developing rotor design in parallel with blade design, acknowledging the interconnectedness of the two systems.
  • It is noted that axial flow compressors and fans have different requirements and behaviors, suggesting a need for clarity in the design focus.
Participants generally agree on the importance of considering machining capabilities and the interrelation of rotor and blade design. However, there are competing views regarding the optimal design choice between dovetail and fir tree attachments, and the discussion remains unresolved on specific geometric relationships and initial dimensions.
Participants mention limitations in available resources, such as the lack of access to CNC machining, which may affect design feasibility. There is also an acknowledgment of the need for further refinement of dimensions and relationships in the design process.
Nutria360
Hi guys! I am studying mechanical engineering and have set myself a personal project to design a blade, either for a compressor or an axial fan (to learn a bit). I have found quite a few books on the aerodynamic and thermodynamic design of such equipment, but I still haven't found information about root attachments for blades (Dovetail and Tree are a couple that I have come across). I wanted to know if you have any information about their initial geometric relationships (to get an idea of the dimensions and initial shape they would have). Thank you very much!
Welcome to PF.
Google: turbine blade root design
The design will depend on the fluid. Is that an air, steam, or combustion gas turbine?
It’s also going to depend on what machining capabilities you have access to.
That said, I can’t recall the last time I saw an actual dovetail blade root. Maybe on a fan stage? The fir tree design is popular because it fits better into a hub of densely packed blades, provides excellent surface area for load distribution, and uses less material overall to achieve the same load bearing capacity. The tradeoff is the higher level of precision machining required, but if you’re doing axial flow turbines, you need that level to precision machining anyways.
Baluncore said:
Welcome to PF.
Well, my idea is to design an axial fan whose working fluid is air. As I mentioned, I have found many documents and books that cover the design of the blades, but very few show the blade with its root (whether dovetail or tree).
Yes, what I want to design is an axial fan. According to my research, it is also necessary to consider rotordynamics and aeroelasticity. While I have found both types of roots and their profiles, I haven’t found some basic relationships to have a starting point. I imagine that I would have to create a preliminary design following the profile and then refine the dimensions until I achieve a more precise design. Machining is not an issue because I don’t have access to CNC in my country, so the idea is to make it more conceptual.
Then a dovetail design would be my recommendation, just for the simpler geometry and calculations
Thank you very much for your recommendation; I will take it into account for the design I will be working on. If I am not mistaken, the most optimal way to achieve an acceptable design would also be to consider the rotor design and develop both aspects in parallel.
Yes, since it’s a complete system.
That said, axial flow compressors and fans have very different requirements and behaviors. I would suggest narrowing that choice down early.
  • · Replies 28 ·
