Block Time & Action at a Distance
  • Context: Undergrad
  • Thread starter Thread starter InterestedParty
    Block Time
The discussion revolves around the concept of 'Block Time' as proposed by Einstein and its implications for 'action at a distance' and quantum mechanics (QM). Participants explore whether Block Time can provide a framework for understanding entanglement and the nature of time in relation to quantum phenomena.
  • One participant suggests that if the Universe exists in Block Time, it could imply that particles remain in contact with themselves, potentially explaining action at a distance.
  • Another participant counters that Block Time does not support action at a distance or clarify entanglement, indicating a misunderstanding of the concept.
  • A question is posed about whether there is a QM interpretation that aligns with the idea of time as a permanent state, which is clarified as contrary to the principles of Block Time.
  • It is noted that the lack of an absolute universal "now" is significant for understanding entanglement, as it complicates the notion of causality between measurements of entangled particles.
  • One participant points out that while one can measure entangled particles in a specific order, QM does not allow for a definitive conclusion about causation between them.
  • A reference is made to an interpretation of QM called Relational BlockWorld (RBW), which incorporates elements of Block Time, suggesting further exploration in a dedicated subforum.
Participants express differing views on the implications of Block Time for action at a distance and entanglement. There is no consensus on the relationship between these concepts, and the discussion remains unresolved regarding the interpretations of Block Time in relation to quantum mechanics.
Participants highlight that the concept of Block Time raises philosophical questions rather than providing testable predictions in physics. The discussion also reflects on the limitations of interpreting quantum measurements and causality within the framework of QM.
InterestedParty
TL;DR
Block Time and entanglement
Sorry, for the lack of correct terminology - this may be answered elsewhere on the forum, I haven't been able to find it.
If the Universe is in Einstein's 'Block Time', then does this provide a mechanism for 'action at a distance'? Rather than a particle being split and entangled, if viewed in Block Time it would look like one particle being stretched (a single line), not two separate particles. As such it always remain in contact with itself and account for the interaction.
InterestedParty said:
Summary:: Block Time and entanglement
Your question is based on a misunderstanding of block time. It supports neither action-at-a-distance, nor does it explain entanglement.
LOL! Thanks for taking the time to respond, I appreciate it:)
Could I just ask: if time *were* viewed as all future and past permanently existing in the same moment, is there a QM way of describing that as a concept?
That's exactly what block time isn't. See the bit I've highlighted. There's no sense in which the entire spacetime exists at a moment in time. Time itself is part of the block universe. Causality and the flow of time, as measured by the evolution of physical processes, is not affected by the concept.
In fact, the block universe raises philosophical questions rather than makes any meaningful difference to physics. Whether or not the universe is a block universe is not something that can be tested. It's more of a metaphysical interpretation of the theory of relativity and the nature of spacetime.
PS The thing to learn from relativity is that the concept of a universal "now" is meaningless - which is what allows the block universe interpretation in the first place. The problems start when you then forget this and imbue an arbitrary "universal now" with some physical significance.
Thanks again. I understand that that's what block time isn't, I was just wondering if there was anything like it in QM, but you've answered my question.
The lack of an absolute universal now is important for entanglement as follows:
If entangled particles are separated by a sufficient distance, then (*) it is not possible to say unambiguously which one is measured first. If someone proposes, therefore, a mechanism by which the particle that gets measured first sends a message to the other particle, then it's not possible even to say which particle is supposed to be sending the message.
(*) To be more precise, you can conduct the experiment in such a way that it is not possible to say unambiguously which one is measured first. Technically this means that the measurement events must be spacelike separated.
Ahhhh, that makes sense, thanks, a good summation:)
If entangled particles are separated by a sufficient distance, then it is not possible to say unambiguously which one is measured first. If someone proposes, therefore, a mechanism by which the particle that gets measured first sends a message to the other particle, then it's not possible even to say which particle is supposed to be sending the message.
Not disputing this, but pointing out an additional point: You can certainly unambiguously measure one before the other. But there is no observable difference possible from the predictions of QM. It is not possible to conclude that A causes B any more than you say B causes A : except by assumption.
@InterestedParty : There is an interpretation of QM that features elements of block time. That interpretation is best discussed in the PF subforum on quantum interpretations. The interpretation is called Relational BlockWorld (RBW), and is quite sophisticated. See this breezy 47 page intro: https://arxiv.org/abs/0908.4348
Good point. I've clarified that post.
'Breezy' indeed, thanks for the link and the directtion:)
  • · Replies 112 ·
13K
  • · Replies 91 ·
  • · Replies 44 ·
  • · Replies 58 ·
  • · Replies 43 ·
  • · Replies 23 ·
  • · Replies 16 ·
  • · Replies 87 ·
9K
