Blocks on a Pulley: Friction & Acceleration
  • Thread starter Thread starter jti3066
    Blocks Pulley
12 replies · 3K views · last reply
jti3066
A 5.0 kg block on a table is attached to a 4.0 kg block by a light string which passes over a light frictionless pulley. The coefficient of kinetic friction between block 1 and the table is U_k= 0.30. At time t = 0, block 1 is moving toward the pulley with a speed of 0.1 m/s.
A) What is the frictional force acting on Block 1?
B)What is the acceleration of Block 1?
F_net = ma
F_f = u_k(m_1)(g)
A) F_f = 0.30 * 5 * 9.81 = 14.72 N
B) T_1 = T_2
T_1 - u(m_1)g = m_1(a)
T_2 - u(m_1)g = m_1(a)
m_2(g) - u(m_1)g = m_1(a)
a = (((m_2)g)/m_1) - ug = 4.905 m/s^2
hi jti3066! :smile:
(have a mu: µ and try using the X2 and X2 icons just above the Reply box :wink:)
B) T_1 = T_2
A) is right :smile:
but i don't understand your B) :confused:
Thanks...
Well, for part be I set up the F_net equation for block one, and the tension from the block to the pully is equal that of the tension in block 2...ie tension in the string...So the first equation I said, "The tension in T_1 minus the force of friction equals the mass 1 times acceleration". From their I know that T_1 = T_2, and T_2 equals mass 2 times g.
Substitution and then sovle for a.
hi jti3066! :smile:
jti3066 said:
… T_2 equals mass 2 times g.
oh i see!
no, how can T2 = m2g?
m2 is accelerating! :redface:
jti3066 said:
duh...T_2 = m_2(a)
no! …
T2 - m2g = m2a :rolleyes:
(Ftotal = ma)
jti3066 said:
B) a = [m_2(g) - um_1(g)]/(m_1 - m_2)
almost right :smile:
useful tip …
you only have to look at that to see it must be wrong …
if m1 = m2, that would make the acceleration infinite! :biggrin:
Ok i give up...what would be the proper equation and why...Please
hi jti3066! :smile:
(just got up :zzz: …)
you've made a mistake in a ± sign somewhere …
go back through your equations and see where it was! :wink:
B) T_1 - um_1g = m_1a
m_2g - T_2 = m_2a
a = [(m_2g - um_1g)]/(m_1+m_2)
Yup! :biggrin:
(btw, you could have got the same result by treating everything as being in a line, and using F = ma on the two blocks as a single body, with force m2g to the left, and µm1g to the right! :wink:)
