How Much Force Does a 15 kg Block Exert on a 20 kg Block on an Inclined Plane?
The discussion centers on calculating the force exerted by a 15 kg block (m2) on a 20 kg block (m1) on a 20-degree inclined plane, with a 200N force applied. Initially, the calculation suggested that m2 exerts 267N on m1, assuming no friction. However, after considering kinetic friction (μk = 0.1), the revised calculation indicates that m2 exerts approximately 234.8N on m1. Participants emphasized the importance of accounting for friction and the net forces acting on the blocks to achieve accurate results.
  • Understanding of Newton's laws of motion
  • Knowledge of inclined plane physics
  • Familiarity with trigonometric functions (sine and cosine)
  • Basic concepts of friction in physics
  • Study the effects of friction on inclined planes in physics
  • Learn to apply Newton's second law (F = ma) in various scenarios
  • Explore advanced problems involving multiple blocks on inclined planes
  • Investigate the role of kinetic and static friction in motion analysis
Students studying physics, educators teaching mechanics, and anyone interested in understanding forces on inclined planes and the impact of friction on motion.
techie86
We have an inclined plane, 20 degrees, with two blocks on it. The higher block (m2) is 15 kg and the lower block (m1) is 20 kg. A 200N force is applied to the blocks and they move up the inclined plane at a constant speed. What force does the 15 kg block exert on the 20 kg block?
F = ma
My thinking is as follows. The net force in the parallel direction must be zero since we have a constant speed. Therefore, the sum of the forces from blocks 1 and 2 must equal 200N.
m1*g*sin(20) + m2*g*sin(20) = 200N
We want the force that the higher block (m2) exerts on the lower block (m1).
m2*g*sin(20) = 200N - m1*g*sin(20)... so we need to find 200N - m1*g*sin(20).
This comes out to: 200N - (20kg)(-9.8 m/s^2)*sin(20 deg) = 200 - -67 = 267 N.
Does this answer make sense to anyone?
Thanks!
F = ma
Thanks!
have you considered whether there is any friction, as I don't think you said the surface was smooth?
Oh dear, yes I forgot! The kinetic friction is 0.1. If I had to guess, this might change my answer as:
Fparallel - Ffriction for each block...
m1*g*sin(20)-0.1*m1*g*cos(20) + m2*g*sin(20)-0.1*m2*g*cos(20) = 200N
m2*g*sin(20) = 200N - m1*g*sin(20) + 0.1*m1*g*cos(20) + 0.1*m2*g*cos(20)... so we need to find 200N - m1*g*sin(20) + 0.1*m1*g*cos(20) + 0.1*m2*g*cos(20).
This comes out to: 200N - 20*-9.8*sin(20) + 0.1*20*-9.8*cos(20) + 0.1*15*-9.8*cos(20) = 234.8N
Maybe this is right?
I doubt it.
It takes only 196 N to LIFT a 20kg block. It is going to take a lot less than that to move it up the slope.
The force acting down the slope on the 20kg block are a component of the weight force - less than half the 196 N weight force, plus the friction force, less than 0.1 x the weight force, so the answer will be less than 0.6 x 196 N.
By correctly applying the sine and cosine factors you should get the real answer.
btw: When a 200N force is applied to this pair of masses I don't think it will move at constant speed if μk = 0.1. It will accelerate up the slope.
  • · Replies 17 ·
  • · Replies 19 ·
