Blowing up a balloon (thermodynamics and ideal gases)
The discussion centers on calculating the work done by air when inflating a balloon, governed by the pressure equation P = CV³, where C = 100 kPa/m³. The work done is derived using the integral W = ∫(C * V * dV) from an initial volume of 1 m³ to a final volume of 3 m³. Participants clarify that the pressure varies with volume, necessitating integration to find the work, and they confirm that the resulting units align with work (Joules).
  • Understanding of thermodynamics principles
  • Familiarity with integral calculus
  • Knowledge of the ideal gas law
  • Basic concepts of pressure and volume relationships
  • Study the derivation of work done in thermodynamic processes
  • Learn about the ideal gas law and its applications
  • Explore integration techniques for variable pressure functions
  • Investigate unit conversions in thermodynamics, particularly between kPa and Joules
Students studying thermodynamics, engineers working with gas systems, and anyone interested in the mathematical modeling of physical processes involving gases.
doctordiddy
1. Homework Statement
A balloon behaves such that the pressure is P = CV3
where C
= 100 kPa/m3
. The balloon is blown up with air from a starting volume of 1 m3
to a volume
of 3 m3
. Find the work done by the air.
2. Homework Equations
W=PdV
3. The Attempt at a Solution
What I tried is simply trying the above solution by multiplying the P which is given by P=CV^3 by the change in volume
so i got
W=(CV^3)(Vf-Vi)
I then realized I had no idea what would the V in this equation be, can someone tell me if I am even doing this question right and if I am how I can determine the V?
Thanks
Hint: This will be an integration problem because P is a function of V.
Do I use the formula W=∫VfV1PdV?
That's what I have been trying to do but I'm not sure how to do this with two different P because you can usually move the P out of the integral
edit: nvm i think i figured it out, should it looook something like this
PiVi = PfVf
so
Vf/Vi = Pi/Pf
and then replace Vf/Vi with Pi/Pf to get
W = nR*ln(Pi/Pf)
The pressure is a constant times volume. So the integral would be
W = integral(C * V * dV) from 1 m^3 to 3 m^3.
Check the units and you'll see that the units are work.
could I instead just find the initial and final pressures and then directly plug them into the modified version of the ideal gas formula like in my edit above?
Also i tried to do the integral you told me to do above, should I end up with 31| C*3V2?
How do you determine n without knowing the temperature?
yeah I realizd that when i started doing the calculations
however when I plug everything in I end up with units in kPa instead of joules... unless the integral of V would change it's units?
also, my answer of 7800J seems unrealistically high so i think i might be doing something wrong.
You have
W = integral ( (kPa/Volume) * Volume * dVolume) = kPa * Volume after integration
kPa is Newtons/area
So you get Newtons-meters
Hope this has helped. I have to leave my computer now.
LawrenceC said:
You have
kPa is Newtons/area
just one last question, can you give me an approximate value of Joules that would be needed in this question? I just need a reference to determine whether or not my answer is plausible and i have no idea how much 1 joule is.
Thanks.
ok nvm then, thanks a lot for the help!
9K
  • · Replies 19 ·
10K
  • · Replies 23 ·
