Boiling point and connection distance of the elements
The discussion focuses on the boiling points and connection distances of hydrogen halides, specifically HF, HCl, HBr, and HI. HF has the highest boiling point due to hydrogen bonding, while the others exhibit weaker intermolecular forces, leading to lower boiling points. The connection distances increase down the group, reflecting the larger atomic sizes of the halogens. Misunderstandings about ionic versus covalent bonding and the influence of electronegativity on bond polarity were highlighted. Recommendations for further learning included video lessons and texts, particularly emphasizing particle-level descriptions to understand these concepts better.
José Ricardo
Explain the following order of the boiling point (° C)
HF (19.5)> HCl (-85.1) <HBr (-66.8) <HI (-35.4)
b) Explain the following order of connection distance (pm):
HF (92) <HCl (127) <HBr (141) <HI (161)
xxx
a) HF does hydrogen bond, and the others make ionic linking.
b) The lower the atomic mass, the higher the boiling point
This statement are wrong. (How?)
And the others make covalent linking, not ionic (generally means electrovalent in some texts)
You mean the intermolecular one, that too in an aqueous solution
Likes José Ricardo
How does the electronegativity of the halogens & hence the H-X bond polarity change down the group?
Likes José Ricardo
José Ricardo said:
HF (19.5)> HCl (-85.1) <HBr (-66.8) <HI (-35.4)b) The lower the atomic mass, the higher the boiling point
Does not constitute an explanation, nor fits the data very well!
Likes José Ricardo and baldbrain
Also, the statement
makes it a bit ambiguous to know whether you've understood the concept of hydrogen bonding
Likes José Ricardo
And the others make covalent linking, not ionic (generally means electrovalent in some texts)You mean the intermolecular one, that too in an aqueous solution
Yes, you're right! Ionic linkings are stronger! The best example is our kitchen salt, which your trying to separate stove, you can't because the boiling point of the NaCl is 900 °C and only in industries is possible to separate the sodium from the chlorine.
Yes, I made a mistake.
Yes, I don't know how to do this question.
baldbrain said:
Also, the statement
I didn't even internalized this subject. Could you recommend me a video lesson about this subject?
To begin with, watch this:
@José Ricardo After watching that, you can guess that these molecules get 'associated' (get closer together due to attractions) with each other. Think, how will that affect the boiling point?
I find that working out answers to questions like these are best done by starting with a particle level description (i.e., what the atoms or molecules are doing). An excellent written source for that is Richard Feynman's Atoms in Motion.
There are video's of Feynman informally talking about much of the material, like this and this. I find the text, though, more useful.
Likes baldbrain
12K
30K
  • · Replies 18 ·
10K
