Why does C-C have a higher bond energy than B-N in hBN and graphene?
  • Thread starter Thread starter james weaver
    Bond Strength
The discussion focuses on hexagonal boron nitride (hBN) nanotubes and their thermal conductivity compared to graphene. It highlights that graphene exhibits significantly higher thermal conductivity due to its electrical conductivity, which allows electrons to contribute to heat transfer. While both materials have similar phonon spectra, hBN acts as an electrical insulator, limiting its thermal conductivity. The conversation also touches on bond energies, noting that carbon-carbon bonds in graphene are stronger due to their double bond nature and delocalized electrons, despite hBN being isoelectronic with graphene. The polar nature of hBN's bonds is acknowledged, but it is emphasized that the primary factor for the thermal conductivity difference lies in the materials' electrical properties.
james weaver
Hi everyone, this is my first post in the chemistry section. I am doing a project for my engineering class on "cutting edge" materials and the one I chose is hexagonal boron nitride (specifically in the form of nanotubes). In comparing hBN to graphene, I need to explain to the class why graphene has a much higher thermal conductivity. From what I've read, non-metals transfer heat via vibrations in their lattice structures. As I understand it, atoms with higher bond energies have a stiffer spring-like effect which enables them to transfer heat quicker (makes sense because B-N has lower bond energy than C-C). My question is this:
Why does C-C have a higher bond energy than B-N? I thought that non-polar bonds in general have lower bond energies, and this case C-C has the less polar bond but higher bond energy.
Chemistry news on Phys.org
DrClaude said:
The carbon-carbon bonds in graphene are double bonds and the electrons are delocalized over many carbon atoms
hBN seems to be isoelectronic with graphene, which suggests bonds of a comparable strength, doesn't it?
Good point. But the bonds are highly polar.
The bond strength in hBN is similar to that of graphene. The thermal conductivity difference is almost entirely because of the electrical conductivity difference.
Thermal conductivity in general is determined by propagation of energy through the lattice, in the form of either phonons or electrons. hBN and graphene have similar phonon spectra, but hBN is an electrical insulator, whereas graphene is an electrical conductor, so electrons contribute substantially to the thermal conductivity in graphene but not hBN.
Likes jim mcnamara, Borek, HAYAO and 1 other person
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
