Eigenvalues and Eigen-vectors for Botched Homework | Characteristic Equation
The discussion focuses on finding the characteristic equation, eigenvalues, and eigenvectors for a given matrix. The characteristic equation is determined to be (\lambda + 5)(\lambda - 7)(\lambda - 3), leading to eigenvalues of -5, 7, and 3. The confusion arises when calculating the eigenvectors, particularly for the eigenvalue -5, where the reduced row echelon form yields a system of equations. The correct eigenvector corresponding to -5 is identified as <-16, 4, 9>, derived from the equations generated during the calculation process. The participant seeks clarification on their calculations and understanding of the eigenvector results.
SadSack
(a) Find the characteristic equation and
(b) the eigenvalues and corresponding eigen-vectors
[-5 0 0
3 7 0
4 -2 3]
det(\lambda*I - A)
Finding the characteristic equation wasn't that challenging, I took lambda, \lambda , and subtracted the given matrix values from it for every diagonal entry. The determiant of a 3x3 matrix is just the product of these diagonals...I think so my characteristic equation is (\lambda + 5)(\lambda-7)(\lambda - 3)
Next the eigenvalues are the values for \lambda that when plugged in would make the characteristic equation equal zero...so the eigenvalues are -5, 7, 3
This is where I'm confused.
To find the eigen-vectors I'm supposed to multiply each eigenvalue by the identity matrix and subtract the original given matrix: so for the eigenvalue of -5...
[-5 0 0
0 -5 0
0 0 -5]
MINUS
[-5 0 0
3 7 0
4 -2 3]
which equals
[0 0 0
-3 -12 0
-4 2 -8]
I took the reduced row echelon form of this matrix and got...
[1 0 1.777
0 1 -.4444
0 0 0]
Is my eigen vector in the matrix above? I am so confused...I also tried to solve the system generated by multiplying a 3x1 vector of variable components x, y, z times
[0 0 0
-3 -12 0
-4 2 -8]
I appear to have failed miserably at this...because the vector I got did not work. Can someone help walk me through this?
[-5 0 0
3 7 0
4 -2 3]
det(\lambda*I - A)
Yes, in an "upper triangular" or "lower triangular" matrix like this, the eigenvalues are just the numbers on the main diagonal.
[-5 0 0
0 -5 0
0 0 -5]
MINUS
[-5 0 0
3 7 0
4 -2 3]
which equals
[0 0 0
-3 -12 0
-4 2 -8]
[1 0 1.777
0 1 -.4444
0 0 0]
Which is equivalent to the equations x+ 16/9 z= 0 and y- 4/9 z= 0 so x= -16/9 z and y= 4/9 z. Any eigenvector corresponding to eigenvalue -5 is of the form <-16/9 z, 4/9 z, z>. Since you only need one, you can take z= 9 to get rid of the fractions: <-16, 4, 9>.
[0 0 0
-3 -12 0
-4 2 -8]
So your equations would be 0= 0, -3x- 12y= 0, and -4x+ 2y- 8z= 0. From -3x- 12y= 0, x= -4y. Putting that into -4x+ 2y- 8z= 0 gives 16y+ 2y- 8z= 0 so 18y= 8z and y= (4/9)z and x= -4y= (-16/9)z. That gives the same answer as before, <-16, 4, 9>.
[quoteI appear to have failed miserably at this...because the vector I got did not work. Can someone help walk me through this?
  • · Replies 23 ·
