Bounce of the cue ball in snooker
  • Context: Undergrad
  • Thread starter Thread starter TSN79
    Ball Bounce
The discussion revolves around the behavior of a cue ball in snooker, particularly focusing on its speed when bouncing off the cushions. Participants explore the physics behind the ball's rebound speed, the effects of spin, and the perception of speed changes during gameplay.
  • Some participants question whether a cue ball can rebound off a cushion faster than it approached, suggesting that spin may play a role in this phenomenon.
  • Others propose that the perception of increased speed may stem from expectations of speed reduction upon impact, rather than an actual increase in speed.
  • A participant mentions the analogy of a "superball," noting that spin can convert rotational kinetic energy into linear kinetic energy, potentially explaining faster rebounds.
  • Concerns are raised about the transfer of spin to the cushion and how that might affect the cue ball's rebound behavior.
  • One participant references a study from Loughborough University regarding ball behavior under cushion impacts, indicating that while the study is informative, it becomes complex.
  • Another participant notes the absence of a standard coefficient of restitution for billiard cushions, emphasizing the importance of bounce accuracy across different speeds.
Participants express differing views on whether the cue ball can rebound faster than it approached, with some attributing this to spin and others suggesting it may be a perceptual illusion. The discussion remains unresolved regarding the exact mechanics involved.
Participants acknowledge limitations in understanding the physics of cushion impacts, including the need for further analysis of speed before and after impact and the complexities introduced by spin.
TSN79
I was watching a game of snooker, and sometimes the cue ball bounces off the cushions with surprisingly high speed. Some people often say that it comes off the cushion faster than it went into it. And I started thinking - is that even possible? Does physics work that way?
Maybe if it has spin
Yes top spin giving angular momentum which will not be apparent from a normal view point. You can see a slowed down cue ball with spots more easily like in this video.
Have you ever played with a "superball" (high friction bouncy rubber ball)? If you give them lots of spin, they shoot off very fast at bounce. Rotational kinetic energy is converted into linear kinetic energy.
I think the effect is that the trained eye expects a certain reduction in speed upon impact with the cushion. When this doesn't happen and the ball rebounds faster than expected it creates the illusion that it speeded up.
That said, I would like to see some analysis of the speed of a ball before and after it strikes the cushion.
The cases in question are not where spin is involved. Those cases are known and understood.
Will the spin not be transferred to the cushion once it strikes?
Intuitively I would thought the energy is transferred to a small point on the rubber cushion which recoils then springs back pushing the cue ball out again.
This is from playing the game (pool not snooker) and trying to adopt some physics I understand (to some extent)
Also, I found this study from Loughborough university – it made sense then got tricky edit not impossible
https://dspace.lboro.ac.uk/dspace-jspui/bitstream/2134/15087/3/Ball%20behaviour%20under%20under%20cushion%20impacts.pdf
Let me know what you think and an idiots guide would be appreciated.
I could not find a standard coefficient of restitution for billiard cushions, although the above reference indicates what one might expect. The cushions are made of rubber (natural or synthetic), and accuracy of bounce over a range of speeds is a key performance measure.
  • · Replies 214 ·
24K
  • · Replies 45 ·
