Bound charges - Question about the maths. Did I calculate this correctly?
  • Thread starter Thread starter phyzmatix
    Bound Charges
The discussion centers on calculating bound surface charge density (\sigma_b) and bound volume charge density (\rho_b) for a sphere with a polarization defined as P(r) = kr, where k is a constant. The correct expressions derived are \sigma_b = kr and \rho_b = -3k, with the importance of using the divergence operator in spherical coordinates emphasized. Participants clarified the distinction between the divergence and gradient, and the necessity of expressing vectors consistently in either spherical or Cartesian coordinates to avoid confusion.
  • Understanding of polarization in electrostatics
  • Familiarity with divergence and gradient operators
  • Knowledge of spherical and Cartesian coordinate systems
  • Basic principles of vector calculus
  • Study the divergence operator in spherical coordinates
  • Review vector calculus, focusing on conversions between spherical and Cartesian coordinates
  • Explore examples of bound charges in electrostatics
  • Practice problems involving polarization and charge density calculations
Students and professionals in physics, particularly those specializing in electromagnetism, as well as educators seeking to clarify concepts related to bound charges and polarization in materials.
phyzmatix
We know that a sphere of radius R carries a polarization P(r)=kr where k is a constant and r the vector from the centre. Calculate \sigma_b and \rho_b
If we let the direction of polarization coincide with the z axis then:
\sigma_b=\textbf{P}\hat{n}
\sigma_b=kr\cos\theta
and
\rho_b=-\nabla\textbf{P}
\rho_b=-\nabla kr\hat{r}
\rho_b=-kr (\hat{x}\frac{d}{dx}+\hat{y}\frac{d}{dy}+\hat{z}\frac{d}{dz}) (\sin\theta\cos\phi\hat{x}+\sin\theta\sin\phi\hat{y}+\cos\theta\hat{z})
\rho_b=0
My query is mostly about these last three steps...are they correct? I'm still struggling to wrap my head around substituting the right infinitesimals for integration problems and, as in this case, the right coordinates for vectors.
Thanks for the help!
phyz
If the polarization is radial, how can the direction of polarization coincide with the z axis?
Technically a dot product:
\sigma_b=\textbf{P}\cdot\hat{n}
but you probably knew that ;-)
Stop right there: you're mixing coordinate systems. Your derivative is expressed in Cartesian coordinates, but the radial vector is expressed in spherical coordinates. Now, you could keep going with this, by using the chain rule; you would have to calculate the coordinate derivatives
\frac{\mathrm{d}r}{\mathrm{d}x}, \frac{\mathrm{d}r}{\mathrm{d}y}, \frac{\mathrm{d}r}{\mathrm{d}z}, \frac{\mathrm{d}\theta}{\mathrm{d}x}, \frac{\mathrm{d}\theta}{\mathrm{d}y}, \frac{\mathrm{d}\theta}{\mathrm{d}z}, \frac{\mathrm{d}\phi}{\mathrm{d}x}, \frac{\mathrm{d}\phi}{\mathrm{d}y}, \frac{\mathrm{d}\phi}{\mathrm{d}z}
but that'd be kind of a pain. It would be much easier to express the radial vector in terms of x, y, and z.
The thing is, I don't KNOW if the polarization is radial...I'm basing my (obviously very dangerous) assumption on a similar example (there is only one, can you believe it) in my textbook. So what do you suggest? Is there a way around this?
Sorry, LaTex oversight on my part :smile:
Now you see, this is exactly my problem. I simply don't get this stuff :redface:
I thought
was expressing spherical coordinates as Cartesian :cry:
So how do I start fixing this?
You are mixing the equations for the scalar components and the vector components.
If you want the scalar x coordinate converted from spherical coordinates, then x=R\sin\theta\cos\phi.
If you want the x component of a vector converted from spherical coordinates, then A_x = A_R\sin\thea\cos\phi+A_\theta\cos\thea\cos\phi-A_\phi\sin\phi.
I always keep a set of photocopies of various conversion charts hung up in my cube for handy reference.
But like diazona suggested, use the divergence operator that is for spherical coordinates, it will make this so much easier.
Thanks for the input so far! :smile:
OK, I'm still not sure if I fully understand this, but could you tell me if my revised attempt is at least on the right track?
\rho_b=-k (\hat{r}\frac{d}{dr}+\hat{\theta}\frac{1}{3}\frac{d}{d\theta}+\hat{\phi}\frac{1}{r\sin\theta}\frac{d}{d\phi}) (r\hat{r})
\rho_b=-kr
I'm still not so sure if my vector expression (r\hat{r}) is correct or if there's supposed to be a couple of theta's and phi's in there :frown:
The problem statement says, "P(r)=kr where k is a constant and r the vector from the centre". A vector from the center of the sphere is radial, by definition.
You need the divergence, not the gradient:
\rho_b=-\nabla \cdot \textbf{P}
Divergence in spherical coordinates
You do have the correct form for P:
\textbf{P}=kr\hat{r}
The equation for \rho_b is not correct. It should be \rho_b=-\nabla \cdot \vec{P}. Now look up the divergence in spherical coordinates and write down the polarization like this P(\vec{r})=kr \hat{r}.
Returning to the bound surface charge, you have
<br /> \sigma_b=\textbf{P}\hat{n}<br />
As diazona noted, this should be a dot product:
<br /> \sigma_b=\textbf{P} \cdot \hat{n}<br />
You have \textbf{P}=kr\hat{r}. Now, what is \hat{n} on the surface of a sphere, in spherical coordinates?
*doh* :redface:
Thanks...
Oh, ok...So I've been writing it as the dot product (divergence) but treating it as the gradient. Well done phyz! *sigh*
\hat{n} at the surface of a sphere would be perpendicular to the surface...mmmm...so wouldn't it simply be \hat{r}?
Let's try again...
\sigma_b=kr\hat{r} \cdot \hat{r}
\sigma_b=kr\rho_b=-\nabla\cdot\textbf{P}
\rho_b=-\nabla\cdot kr\hat{r}
\rho_b=-(\frac{1}{r^2}\frac{d}{dr}(r^2 kr))
\rho_b=-(\frac{1}{r^2}3kr^2)
\rho_b=-3k
If this is right, then I think I can finally say I'm beginning to understand this (fingers crossed) :biggrin:
Correct!
One more little thing... you have
<br /> \sigma_b=kr<br />
Lower-case r is a variable. To get \sigma_b at the surface of the sphere, you need to substitute the value of r at the surface of the sphere, which is...
Finally, as a "sanity check" for this type of problem, note that when you polarize an object, you don't add or subtract any charge from the object as a whole. So the total bound charge should be zero.
Got it!
Thanks for all the patience and help! Slowly but surely confusion is being beaten into submission with the big stick of comprehension :-p
Have an excellent day! :smile
  • · Replies 21 ·
