Equation of Circle: Boundary or Surface?
  • Context: High School
  • Thread starter Thread starter pairofstrings
    boundary surface
The discussion revolves around the interpretation of the equation of a circle, ##x^2 + y^2 = 1##, and whether it describes a boundary or a surface. Participants explore concepts related to dimensions, boundaries, and surfaces in both 2D and 3D contexts, touching on definitions and classifications of geometric objects.
  • Some participants suggest that the equation of a circle describes a boundary, while the equation of a sphere describes a surface.
  • There is a question about whether a 2D object can be considered a surface.
  • Some participants assert that curves or surfaces can have boundaries, and inquire if a circle can be represented as a boundary.
  • Clarifications are made regarding the dimensionality of objects, with some stating that a circle is a 1D object (curve) and a sphere is a 2D object (surface).
  • One participant expresses confusion about the definitions of shapes like spheres, cones, cubes, and cylinders, and their dimensional classifications.
  • There is a discussion about the collective terminology for points, lines, curves, shapes, and solids, with some proposing the term "mathematical objects" while others challenge its appropriateness.
  • Concerns are raised about the clarity of terms used in geometry and the importance of focusing on significant concepts for learning.
Participants express differing views on the definitions and classifications of geometric objects, with no consensus reached on whether a circle represents a boundary or a surface. The discussion remains unresolved regarding the terminology and dimensionality of various shapes.
There are limitations in the discussion regarding the definitions of boundaries and surfaces, as well as the context-dependent meanings of geometric terms. Some mathematical steps and assumptions remain unresolved.
pairofstrings
TL;DR
Describing boundary or a surface?
Equation of circle: ##x ^2+y ^2=1##. Is this equation describing boundary or a surface?
Thanks.
What do you think?
Can a 2D object be a surface?
PeroK said:
What do you think?
For 2D objects, like circle, the equation describes boundary..?
For 3D objects, like sphere, the equation: x ^2 + y ^2 + z ^2 = 1: describes surface..?
What's the definition of a boundary?
Can a surface be a boundary?
https://en.wikipedia.org/wiki/Surface_(mathematics)
Can a curve be a boundary?
By the way, a circle is a 1D object (curve) and a sphere is a 2D object (surface).
I think that curve or a surface can have a boundary.
So, the boundary of a circle can be represented as ##x^2 + y^2=1##?
I thought Sphere is considered as a 3D object. I was incorrect. So now, out of curiosity, please may I know what a 3D object could be like?
Thanks.
So, the boundary of a circle can be represented as ##x^2 + y^2=1##?I thought Sphere is considered as a 3D object. I was incorrect. So now, out of curiosity, please may I know what a 3D object could be like?
Thanks.
A maths student is a 3d object!
Mathematically it's called a solid. A ball, sphere plus the interior, is a 3d object.
Thanks.
I was looking into points, lines, curves, shapes, solids.
Lines and curves can be referred to as 1D objects ? There is a notion of boundary here?
Shapes, like Sphere, Cone, Cube, Cylinder can be considered as 2D objects? There is a notion of surface here? I can calculate Surface area here?
Solids are 3D objects. There is a notion of surface, volume here. I can calculate surface area, volume here?
Point is a zero dimensional object.
I think things are getting rather confused here. Words like 'Sphere, Cone, Cube, Cylinder' have different meanings according to their context.
Yes.
A line segment is bounded by two points. The boundary of a 2D shape is a (closed) curve.
Strictly speaking the word 'sphere' refers to a 2D surface, but I don't think that is helpful here. We normally consider shapes like triangles, squares etc. as 2 dimensional.
The shape of a coin is called a 'disk' and this is also a 2D object. The boundary of this shape is a 'circle' which, because it is a curve only has 1 dimension but we would not normally refer to a circle as a 1 dimensional object.
pairofstrings said:
Solids are 3D objects. There is a notion of surface area, volume here. I can calculate surface area, volume here?
Yes. When we say sphere, cone, cube, cylinder or prism we are usually referring to a 3D object.
When we want to avoid confusion we say "the surface of a [sphere, cone, cube, cylinder or prism]" or "the interior of a [sphere, cone, cube, cylinder or prism]" to refer to the 2D and 3D objects respectively.
Yes, a point has no dimensions.
So, first there is a point then line/curve then shapes then solids according to ascending order of dimensions?
What is the point, line/curve, shape, solid collectively called? Are they called mathematical objects? Each one of them is a mathematical object?
I don't like the word "shapes" here, perhaps you could use "plane figures".
No, the term "mathematical object" does not have any generally accepted meaning, and there isn't really a collective noun for these geometrical concepts except perhaps each of them could be called a "figure".
If you want to learn about geometry then you should learn about things that are important; asking random questions about things that may not be important will not help you learn. Khan Academy has a suitable set of courses in basic geometry.
