Boundary Value Problem; Eigenvalues and Eigenfunctions
2 replies · 3K views · last reply
Pinedas42
Find the eigenvalues and eigenfunction for the BVP:
y'''+[itex]\lambda[/itex]^2y'=0
y(0)=0, y'(0)=0, y'(L)=0
m^3+[itex]\lambda[/itex]m=0, auxiliary equation
3 cases [itex]\lambda[/itex]=0, [itex]\lambda[/itex]<0, [itex]\lambda[/itex]>0
this first 2 give y=0 always, as the only solution.
[itex]\lambda[/itex]>0 solution attempt
m^3+[itex]\lambda[/itex]^2m=0
m(m^2+[itex]\lambda[/itex]^2)=0
roots:
m=0, and +/- [itex]\lambda[/itex]i
general solution:
y=A+Bcos([itex]\lambda[/itex]x)+Csin([itex]\lambda[/itex]x)
Where A, B, and C are constants
y'=-B[itex]\lambda[/itex]sin([itex]\lambda[/itex]x)+C[itex]\lambda[/itex]cos([itex]\lambda[/itex]x)
y(0)=0 gives
0=A+B, or A=-B
y'(0)=0 gives
0=[itex]\lambda[/itex]C, so C=0
y'(L)=0 gives
0=-[itex]\lambda[/itex]Bsin([itex]\lambda[/itex]L)
The only solution I find from these data is y=0, which seems kind of off since no eigenfunction/values are found. From what I've read/studied so far when [itex]\lambda[/itex]>0 there is always an eigen function/value.
The alternative I've considered is to consider B≠0 and having the eigenvalue be
[itex]\lambda[/itex]L=n[itex]\pi[/itex] giving [itex]\lambda[/itex]=n[itex]\pi[/itex]/L
which then gives the eigen function
y=A+Bcos((n[itex]\pi[/itex]x)/L)
roots:
general solution:
y(0)=0 gives
0=A+B, or A=-B
y'(0)=0 gives
y'(L)=0 gives
That's wrong, your next paragraph is the correct procedure
And since A = -B, you have ##B(-1+\cos(\frac {n\pi x} L))##. You could leave off the B and write ##y_n =-1+\cos(\frac {n\pi x} L)##.
OK, thank you!
I had thought that there always had to be a function for [itex]\lambda[/itex]>0, but I wasn't sure and I couldn't find any literature specifically mentioning it.
