Bounded continous implies uniformly continuous
The discussion revolves around the topic of uniform continuity and its relationship with continuous functions defined on a closed interval [a, b]. Participants are exploring the implications of continuity on compact sets and the definitions involved in establishing uniform continuity.
  • Participants are discussing the definitions of continuous and uniformly continuous functions, with attempts to construct sets related to the continuity properties. There are inquiries about characterizations of uniform continuity using sequences and the implications of compactness on the behavior of functions.
The conversation is active, with various interpretations being explored. Some participants have offered insights regarding the use of compactness in the context of continuity, while others are questioning the necessity of certain definitions and how they relate to the problem at hand. There is a recognition of the need for further clarification on the definitions of compactness being used.
Participants are considering different definitions of compactness, including open covers and finite subcovers, as well as the implications of these definitions on the continuity of functions. There is also a mention of the potential for confusion regarding the use of supremum and infimum in the context of delta neighborhoods.
alanlu
I'm trying to show that continuous f : [a, b] -> R implies f uniformly continuous.
f continuous if for all e > 0, x in [a, b], there exists d > 0 such that for all y in [a, b], ¦x - y¦ < d implies ¦f(x) - f(y)¦ < e.
f uniformly continuous if for all e > 0, there exists d > 0 such that for all x and y in [a, b], ¦x - y¦ < d implies ¦f(x) - f(y)¦ < e.
I constructed
A(d) = { u in [a, b] : x, y in [a, u], ¦x - y¦ < d implies ¦f(x) - f(y)¦ < e }
A = Ud > 0 A(d)
And I think I need to show sup A = b and b is in A, but I'm stuck.
So you know a characterization of uniform continuity using sequences??
That is: f is uniform continuous iff for all equivalent sequences [itex](x_n)_n[/itex] and [itex](y_n)_n[/itex] holds that [itex](f(x_n))_n[/itex] and [itex](f(y_n))_n[/itex] are also equivalent.
Was not aware of this characterization until now. My text does not mention this, so there must be another way.
Isn't this by definition. f is continuous on a compact set so that it is uniformly continuous.
Isn't it true that on a compact set (which [a,b] is), the sup is equivalent to the maximum (and similarly, the inf is the same as a minimum)?
This is true for a continuous function f defined on a compact set K:
[tex]\sup_{x \in K} f(x) = \max_{x \in K} f(x)[/tex]
and
[tex]\inf_{x \in K} f(x) = \min_{x \in K} f(x)[/tex]
How do you propose to use this fact?
P.S. It would help to know what definition of "compact" you are using. There are several definitions that are equivalent on the real line.
Does your definition involve open covers and finite subcovers, or convergent subsequences, or "closed and bounded", or what?
and
Choose ε > 0 and for each x[itex]\in[/itex][a, b], choose δ(x) such that |x - y| < δ => |f(x) - f(y)| < ε (obviously this choice of δ(x) isn't unique, but just pick one for each x). Let δ0 = inf δ(x) (I had incorrectly written sup instead of inf before) on the interval. Then for any x on the interval |x - y| < δ0 implies...?
(Disclaimer: I don't really know much math, so people who actually know this stuff should correct me if I'm speaking nonsense!)
Ansatz7 said:
Choose ε > 0 and for each x[itex]\in[/itex][a, b], choose δ(x) such that |x - y| < δ => |f(x) - f(y)| < ε (obviously this choice of δ(x) isn't unique, but just pick one for each x). Let δ0 = sup δ(x) on the interval. Then for any x on the interval |x - y| < δ0 implies...?
I don't see that it implies much of anything. What am I missing?
Well, ansatz7 did have a disclaimer at the end that it might be garbage, which it is. But I'm also not sure why you need the max and min. Pick a finite subcover (assuming finite subcover is the intended definition of compact) of the delta neighborhoods and pick the min of those deltas. So if |x-y|<delta then shouldn't x and y be in the same delta neighborhood or at worst in overlapping delta neighborhoods? Isn't that the vague picture hint?
What can you then say about |f(x) - f(y)| for any x and y that satisfy |x - y| < δ0? I never did analysis formally, but I think this is valid.
EDIT: Sorry, I very stupidly wrote sup when I meant inf in my post above, so obviously it made no sense - way too tired to be useful. I'll go back and edit now.
Dick said:
Well, ansatz7 did have disclaimer at the end. But I'm also not sure why you need the max and min. Pick a finite subcover of the delta neighborhoods and pick the min of those deltas. So if |x-y|<delta then shouldn't x and y be in the same delta neighborhood or at worst in overlapping delta neighborhoods? Isn't that the vague picture hint?
Pretty much. Some of the deltas in the argument will have to be delta/2 to make it work.
Also, I confused Ansatz7 with the original poster (alanlu), who made no mention of compactness of [a,b] and perhaps doesn't have the appropriate machinery (Heine-Borel) available. That may have been what he was getting at with this Spivak-style construction:
Right, inf would make more sense. However, the inf of infinitely many delta(x) could be zero. This is where the compactness is necessary: to reduce the infinite cover to a finite cover, so "inf" becomes "min" and is strictly positive.
Right, I know that this only works because [a, b] is compact, as I stated in my first post in the thread. I believe it was you who asked how I would use this fact, which is where everything else came from.
Ah thanks! Actually, I did arrive at inf { d(x) }, but I wasn't sure how to turn that into something that is guaranteed to be > 0.
  • · Replies 40 ·
  • · Replies 18 ·
  • · Replies 27 ·
