Bounding the speed of `spooky action at a distance'
  • Context: Graduate
  • Thread starter Thread starter thenewmans
    Speed
The discussion revolves around the concept of "spooky action at a distance" as it relates to quantum mechanics and recent experimental claims of measuring this phenomenon at speeds exceeding that of light. Participants explore the implications of these measurements, the role of reference frames, and the interpretations of quantum mechanics regarding instantaneous effects.
  • Some participants question the validity of measuring "spooky action" at speeds faster than light, suggesting that such measurements may depend on the inertial frame of reference.
  • Others propose that the experiments confirm a lower bound on the speed of spooky action, implying that it could be instantaneous, as predicted by quantum mechanics.
  • There is a discussion about the Earth's reference frame affecting measurements, with some arguing that it can be accounted for by considering specific conditions during the experiment.
  • Some participants express skepticism about the interpretation of instantaneous action, noting that it raises issues related to simultaneity and preferred frames in different reference frames.
  • Participants highlight that while correlations between measurements are observed, this does not imply that information is transmitted faster than light, as entanglement does not allow for faster-than-light communication.
  • There is mention of different interpretations of quantum mechanics, including the many-worlds interpretation (MWI) and Bohmian mechanics, which suggest varying views on the nature of instantaneous effects and causation.
Participants express a range of views, with no clear consensus on the implications of the experimental results or the interpretations of quantum mechanics. Disagreements persist regarding the nature of instantaneous action and the role of reference frames in measurements.
Some limitations include the dependence on definitions of simultaneity, the unresolved nature of backward causation, and the varying interpretations of quantum mechanics that influence the understanding of the measurements and their implications.
thenewmans
These guys claim "Spooky Action at a Distance" is 10,000 times c.
This doesn't make sense to me. Since they're trying to measure a time difference that's faster than light, don't they're measurements depend on their inertial frame of reference? I mean wouldn't they come up with a different answer just by changing they're speed relative to the experiment? I would think they could even pick the speed they want, even backwards in time, just by moving the right way.
Quote from paper:
Here, we strictly closed the locality loopholes by observing a 12-hour continuous violation of Bell inequality and concluded that the lower bound speed of `spooky action' was four orders of magnitude of the speed of light if the Earth's speed in any inertial reference frame was less than 10-3 times of the speed of light.
In any inertial frame, c is the same. So I don't understand that.
(I admit I haven't read the whole thing.)
http://arxiv.org/abs/1303.0614
http://www.extremetech.com/extreme/...stance-at-least-10000-times-faster-than-light
This is interesting, all of the experiments I've read about this had various problems ("locality loops"). Its very interesting that they confirmed its faster than light. Most likely, this just reflects that it is instantaneous as quanum mechanics predicts.
Their actual measurement is just a lower bound on the actual speed, so it doesn't really matter what reference frame you're in, especially if the true speed is infinite. An "infinite" speed would just suggest that entangled particles are connected to each other in such a way that measuring one instantly chooses the other.
The Earth's reference frame IS a factor. We can't be certain as to our overall velocity through space. But by considering a period in which the Earth rotates, you should be able to locate spots in which there is no component of motion between the two measurement points. That would be when those two points define a line perpendicular to Earth's motion. If the speed of spooky action were, say, 2000c then the correlations could not occur because the measurements were taken too closely together (even considering the very high speed of the action). Obviously that never happened, so the speed of spooky action at a distance must be higher.
I think what they mean is this: in the set of inertial frames in which the Earth's speed is less than 10^-3 c, the "speed of spooky action at a distance" measured in their experiment is greater than 10^4 c. They're not trying to say that c itself varies. The "speed of Earth" is a way of picking out a particular set of inertial frames, which as you note, you have to do in order to place limits on the "speed of action at a distance" between spacelike separated events.
I can't find anything wrong with the paper itself, but the extremetech article, as I've come to expect, makes grandiose and unwarranted claims like "now we can have an internet that transmits information much faster than light". Entanglement can't be used to transmit unknown bits of information faster than light.
Got it. Makes sense now. Thanks.
The word "instantaneous" keeps making me think there's a preferred frame. Instantaneous for one frame is backward in time for some other. I just can't get around to thinking that QM makes anything happen instantaneously. To me "instantaneous" just means at the same time or simultaneously, which leaves you with the simultaneity problem.
All they are really "confirming" is that the measurements are spacelike separated; in other words, the error bars on the time and space measurements are small enough to be able to definitely say that the time interval between the events is much smaller than the space interval.
QM doesn't "predict" that anything "happens instantaneously"; it just predicts that the correlations between the spacelike separated measurements are such that the Bell Inequality is violated. Saying that that reflects an "instantaneous collapse of the wavefunction" or something like that is an interpretation of the theory, not a prediction of it.
You are right, kindof. If you imagine the measurement of particle 1 being event A, and the measurement of particle 2 being event B, the relative time between these two events is free to vary. If they are simultaneous in 1 frame they will occur at different times in another, just like you said. The thing is, it doesn't matter which occurs first. QM predicts that the two particles are unavoidably linked, and the measurements will be correlated no matter when they occur!
When I said "instantaneous" I just meant that you could measure them at exactly the same time and you would still find the same correlation as if you measured them an hour apart. So if you make the measurements simultaneously, you will find that the "spooky action at a distance" is instantaneous. But as Peter mentioned, no information is transmitted between the particles, so nothing is actually traveling faster than light.
idk I just read the extremetech article, I've been to busy to checkout the arxiv paper (bookmarked to read later). I just meant if they did their experiment properly their results would confirm that the measurements are spacelike separated.
I never said collapse of a wavefunction, personally I prefer MWI :P But QM does predict that the QM correlations are preserved even under spacelike separation. Speaking in lay terms, I would call this predicting that the spooky action at a distance is instantaneous
The Bohmians do believe that there is truly instantaneous cause/effect. And there is a body of work that says that the Bohmian view does lead to a preferred reference frame. Although that is denied by some.
Also: what is wrong with backwards causation? (Or more properly, a context that includes future components?) This seems perfectly in keeping with many of the sophisticated new experiments on correlations between particles that have never interacted.
I'm not sure that equating "spacelike separated" with "instantaneous" is standard "lay person" terminology, but I can see how the concepts are connected, yes.
I'm not familiar with these, can you give any links?
Here is a great example, and it is difficult (at least for me) to imagine a mechanism for this which does not span time in a manner we are not accustomed to.
http://arxiv.org/abs/1209.4191
Entanglement Between Photons that have Never Coexisted
E. Megidish, A. Halevy, T. Shacham, T. Dvir, L. Dovrat, H. S. Eisenberg
(Submitted on 19 Sep 2012)
"The role of the timing and order of quantum measurements is not just a fundamental question of quantum mechanics, but also a puzzling one. Any part of a quantum system that has finished evolving, can be measured immediately or saved for later, without affecting the final results, regardless of the continued evolution of the rest of the system. In addition, the non-locality of quantum mechanics, as manifested by entanglement, does not apply only to particles with spatial separation, but also with temporal separation. Here we demonstrate these principles by generating and fully characterizing an entangled pair of photons that never coexisted. Using entanglement swapping between two temporally separated photon pairs we entangle one photon from the first pair with another photon from the second pair. The first photon was detected even before the other was created. The observed quantum correlations manifest the non-locality of quantum mechanics in spacetime."
Bohmain: Is that the pilot wave theory with the hidden variable going back in time along the path of the particle? I'm kinda partial to that interpretation. I didn't know it could have a preferred frame. I like it because I think it has a nice solution to that problem. I seems to be nicely compatible with special relativity. I always assumed the wave mozies backward through time at the same pace the particle moves forward through time. That way the measurements match all along the path and regardless of when they're done. And nothing instantaneous is needed.
When I hear "instantaneous", I assume it's an interpretation that intentionally excludes backwards through time. Interpretations seam to have one or the other. I prefer back in time only because I don't like thinking about things moving outside the light cone.
Most Bohmian models need to have a preferred reference frame so there's no conflict with relativity but there is a Bohmian model that avoids having a preferred reference frame by accepting "backward causation":
The aim of this paper is to construct a version of Bohm’s model that also includes the existence of backwards-in-time influences in addition to the usual forwards causation. The motivation for this extension is to remove the need in the existing model for a preferred reference frame. As is well known, Bohm’s explanation for the nonlocality of Bell’s theorem necessarily involves instantaneous changes being produced at space-like separations, in conflict with the “spirit” of special relativity even though these changes are not directly observable. While this mechanism is quite adequate from a purely empirical perspective, the overwhelming experimental success of special relativity (together with the theory’s natural attractiveness), makes one reluctant to abandon it even at a “hidden” level. There are, of course, trade-offs to be made in formulating an alternative model and it is ultimately a matter of taste as to which is preferred. However, constructing an explicit example of a causally symmetric formalism allows the pros and cons of each version to be compared and highlights the consequences of imposing such symmetry. In particular, in addition to providing a natural explanation for Bell nonlocality, the new model allows us to define and work with a mathematical description in 3-dimensional space, rather than configuration space, even in the correlated many-particle case.
Causally Symmetric Bohm model
http://arxiv.org/ftp/quant-ph/papers/0601/0601095.pdf
Demystifier's Bohmian model also avoids a preferred frame by treating time like space:
Making nonlocal reality compatible with relativity
http://arxiv.org/pdf/1002.3226.pdf
Cool! I did not know that. It needs a better name. What other interpretations are "causally symmetric"?
  • · Replies 18 ·
  • · Replies 17 ·
  • · Replies 140 ·
15K
