Bounding the volume distortion of a manifold
The discussion centers on the volume distortion of a manifold defined by a $C^1$ bijection $f: U \to \mathbb{R}^n$, where $U$ is a compact set in $\mathbb{R}^k$. The volume distortion is quantified as $G = \det(Df^tDf)$. For the case when $n=1$, it is established that $G = 1 + |\nabla f|^2$. The conversation explores the conditions under which $G$ can be bounded from below for dimensions where $n > 1$, emphasizing the necessity of compactness and the use of finite sub-covers.
  • Understanding of $C^1$ bijections in differential geometry
  • Familiarity with determinants and the Jacobian matrix
  • Knowledge of compact sets in topology
  • Basic concepts of manifold theory
  • Research the properties of the Jacobian determinant in higher dimensions
  • Study the implications of compactness in continuous mappings
  • Explore the relationship between volume distortion and manifold topology
  • Investigate the use of finite sub-covers in the context of manifold theory
Mathematicians, particularly those specializing in differential geometry and topology, as well as students and researchers interested in the properties of manifolds and volume distortion in higher dimensions.
eyenir
Let $U$ be a compact set in $\mathbb{R}^k$ and let $f:U\to\mathbb{R}^n$ be a $C^1$ bijection. Consider the manifold $M=f(U)$.
Its volume distortion is defined as $G=det(DftDf).$ If $n=1$, one can deduce that $G=1+|\nabla f|^2$.
What happens for $n>1$? Can one bound from below this $G$? If so: under which assumptions?
did not you know that the image of a compact set under a continuous mapping is a compact set?
So you suggest taking a finite sub-cover ${U_i}$ such that $M|_{U_i}=\{(x_1,\dots,x_{n-1},g_i\}$ where $g_i:\mathbb{R^{n-1}\to R}$ is a $C^1$ function on $U_i$?
  • · Replies 20 ·
  • · Replies 17 ·
