Break down nitrous oxide by automotive catalytic converter?
Nitrous oxide can be effectively utilized as an oxidizer when passed through a matrix-type automotive catalytic converter, which may require heating to facilitate the breakdown process. This method can potentially generate sufficient heat to combust fuels such as gasoline, ethanol, kerosene, or LPG. The discussion highlights the intent to create a "stand alone" turbocharger for drag racing, reminiscent of the 1960s Turbonique supercharger, while emphasizing safety. Nitrous oxide serves as a powerful oxidizer, particularly at elevated temperatures, enhancing engine power output in both racing and rocket applications.
  • Understanding of automotive catalytic converters
  • Knowledge of nitrous oxide as an oxidizer
  • Familiarity with combustion processes of various fuels
  • Basic principles of turbocharger design and function
  • Research the design and function of matrix-type catalytic converters
  • Study the thermal dynamics of nitrous oxide breakdown
  • Explore fuel mixing ratios for optimal combustion with nitrous oxide
  • Investigate safety measures in high-performance turbocharger fabrication
This discussion is beneficial for automotive engineers, drag racing enthusiasts, and anyone involved in high-performance vehicle modifications, particularly those interested in innovative turbocharging solutions.
Dopie Opie
Can nitrous oxide be broken down for use as an oxidizer by passing through a matrix type automotive catalytic converter? If so, will the matrix need to be heated? Also, will the process create enough heat to combust gasoline, ethanol, kerosene, or LPG? I want to fabricate a "stand alone" turbocharger for drag racing that does NOT use the engine exhaust. Similar to the 1960's Turbonique supercharger, but safer. Thanks, and Happy Motoring!
Why would you need to break it down? Nitrous IS an oxidizer:
It is also used as an oxidizer in rockets and in motor racing to increase the power output of engines. At elevated temperatures, nitrous oxide is a powerful oxidizer similar to molecular oxygen.
https://en.wikipedia.org/wiki/Nitrous_oxide
You mix nitrous with fuel with the proper fuel ratio, ignite the mix and there you go. More info on http://www.daytona-sensors.com/tech_nitrous.html
  • · Replies 19 ·
9K
